How to Install Eclipse?
Discussion in 'Application & Utilities' started by asvaldr, Oct 20, 2013.
  1. asvaldr
    asvaldr New Member
    Oct 18, 2013
    24
    Hi Guys,
    I'm trying to get eclipse (CDT) installed and can't get it to go. Does anyone know how?
    I've Tried
    1. sudo apt-get install eclipse won't work; it gives
    Since i only want eclipse for C++ and i don't want any java crap; installing them wouldn't help? Shouldn't it install any needed dependacies anyway?
    2. Downloading manually can't get it to start.
    i. I downloaded and placed it into the home folder.
    ii. I've then added the following lines to the eclipse.ini (to live above -vmargs)to point it to the jvm and it still won't start
    I tried all sorts of paths for that java and no love.
    After exhaustive googling and attempts i couldn't get either to start.
    NOTE: I'm doing this to use eclipse with OpenCV; i've gotten openCV to compile and once i get an example working with eclipse i'll be posting up a step by step to help others. So when i get this solved keep an eye out for that on these forums.
  2. mkopack
    Eclipse is written in java. You HAVE to have java to get it to run.
  3. asvaldr
    asvaldr New Member
    Oct 18, 2013
    24
    Thanks. The udoo comes with java open-jdk.
    But are you saying I must install eclipse-jdt package aswell?
  4. mkopack
    Dunno, and until mine arrives I can't really help any more than that.
    There is always netbeans as an alternative. It supports C/C++ and it is 100% written in java. I got that to boot up on a raspi so it should work on a Udoo.
    I just hope we can get an actual oracle jDK to use at some point. OpenjDK is DOG slow.
  5. asvaldr
    asvaldr New Member
    Oct 18, 2013
    24
    Today I was trying to use synaptic package manager to install Eclipse. It kept coming up as a broken package due to dependencies; which I kept chasing but it would dead end saying the package was unknown. ....
  6. miousername
    miousername New Member
    Jun 23, 2013
    73
    which are the broken dependecies?
    Which is the error that sto the installation?
    Maybe you have to add some missing repository
  7. asvaldr
    asvaldr New Member
    Oct 18, 2013
    24
    Its a massive chain...
    starting with trying to "eclipse"
    errors off "eclipse-jdt" and "eclipse-pde"
    then jdt fails on "eclipse-platform" and "eclipse-plugin-cvs"
    and...on and on....
  8. renevanderlende
    renevanderlende New Member
    Nov 27, 2013
    I wanted to install Eclipse too, but I read in some forum (can't remember which, sorry) that Eclipse on Linux is a massive memory eater, maybe think twice before installing.
    Also, there may be Eclipse stability issues: I find 3.7.2 (Indigo) on windows quite stable, while 4.2 and 4.3 (used by Google as base for Android Studio) crash regularly with vague errors. Dunno about a 3.7 /3.5 mix as found in the Linux packages....
