Am I the only one thinking this board won't have any delays?
Discussion in 'UDOO X86' started by Triodefreak, Jun 9, 2016.
  1. toriless
    toriless New Member
    Jun 25, 2016
    17
    Since the Udoo supports 3 outputs I assume it can use DP+ and HDMI at the same time but it is unclear about a touch screen for controls and a DP+ or HDMI output simultaneously.
  2. Triodefreak
    Triodefreak Active Member
    Jun 7, 2016
    104
    30
  3. Andrea Rovai
    @Triodefreak @toriless you are off-topic. Please, go to the Pine 64 Forum if you want to start a thread about Pine 64.
  4. Triodefreak
    Jun 7, 2016
    104
    30
    Ok. Indeed off-topic.
    By now it is clear that the board has been delayed hopefully UDOO will come out with a statement this week as promised somewhere else in this forum.
  5. Andrea Rovai
    @Triodefreak this week indeed you'll get more news on the resolution of the problem we found.
  6. toriless
    toriless New Member
    Jun 25, 2016
    17
    Speaking back on topic since you have abandoned the idea of case that can support M.2 devices I assume I will be sending Dustin some more money for a functional C4Labs case that can hold you WiFi and Blue tooth upgrade board along with a M.2 HD like I had to do with that "other" board which has no case that support changing the SD card other than his.
  7. Triodefreak
    Jun 7, 2016
    104
    30
    Riiiiiight...
  8. Triodefreak
    Jun 7, 2016
    104
    30
    Great news! Thanks for the update on the boot problem!
    Andrea Rovai and Maurice like this.
