How to use M4 processor?
Discussion in 'UDOO NEO' started by mibu945, Jan 23, 2016.
  1. mibu945
    mibu945 New Member
    Jan 23, 2016
    I want to study heterogeneous systems.
    I must run C/C++ programs on M4, replacing to write arduino programs.
    How to do?
    Thanks
  3. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    I would suggest :
    1. Spend some time understanding the cortex m3/m4 boot sequence (ie vector tables etc) if you are new to the subject.
    2. Review chapters 2,13,52,61 im6sx reference manual as they indicate differences/features for supporting A9 + M4.
    3. Understand how uboot is used to load & start an m4 program
    4. You can now develop using FreeRTOS on the imx6x, more information can found in the here. Download the RTOS tar and it contain docs + samples. Some of the samples require modification to work on the NEO but that's part of the learning curve. I have built some of them of so they will work.
    jrullan likes this.
  4. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    FYI; to use rpmsg; you must patch the kernel; I was thinking of putting the patches at rpmsg-neo.
    graugans likes this.
  5. graugans
    graugans Administrator Staff Member
    Sep 17, 2015
    328
    141
    Can you please share your patches?
  6. aprchal
    aprchal New Member
    Jan 15, 2017
    sorry for reopening an old thread, but I'm struggling with rpmsg on udoobuntu (udoo neo). My ultimate goal is to have udoobuntu (A9) + freertos (M4), both communicating using rpmsg. Can somebody point out all the necessary changes that have to be done on udoobuntu side? So far I have crosscompiled a few kernel modules (virtio, virtio_ring, virtio_rpmsg_bus, rpmsg-neo, imx_rpmsg_tty, imx_rpmsg_pingpong) - the last two taken from http://git.freescale.com/git/cgit.cgi/imx/linux-imx.git/tree/drivers/rpmsg?h=imx_3.14.52_1.1.0_ga. However, after loading any of the rpmsg-neo or imx_rpmsg_* modules I have no rpmsg device in /dev. So I suppose that I am still missing something - maybe dtb or kernel modification?
    Thanks.
  7. tcmichals
    tcmichals Member
    Feb 25, 2015
    54
    27
    graugans and Andrea Rovai like this.
  8. Borbarad
    Borbarad New Member
    Mar 1, 2017
    @aprchal
    I'm using the kernel mentioned by @tcmichals. The problem is, that the dtb files didn't have entries for rpmsg. Even mor frustrating was, that dmesg | grep rpmsg produced this:
    [ 0.147736] imx rpmsg driver is registered.
    'imx6sx.dtsi' should contain a disabled entry.
    I added
    &rpmsg{
    status = "okay";
    Now I dmesg | grep rpmsg returns an additional entry:
    [ 0.147631] virtio_rpmsg_bus virtio0: rpmsg host is online
    Now the examples are working. I hope this helps.
