Udoo x86
Discussion in 'UDOO X86' started by PeterRobinson, Feb 23, 2017.
  1. PeterRobinson
    PeterRobinson New Member
    Feb 23, 2017
    14
    Hello,
    I am considering using the Udoo x86 for a project but I have a few questions.
    Is there a way to connect a touch screen display to the board other than the HDMI interface? I do not see any other on boards connections or kits available. I would be extremely interested if there was a 7" touch screen display that could connect directly to the board without the need for an additional power supply. I can most likely make a work around but I was curious if something already existed. Trying to make a tablet.
    milaremi likes this.
  2. milaremi
    milaremi New Member
    May 5, 2016
    17
    10
    I too am interested in this...Andrea?
    This was one of the items that was a quite popular request when you put out your request for accessories (further down in this forum).
    Thanks and keep up the good work!
  3. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    A USB powered touch screen might be a good option.
  4. PeterRobinson
    Feb 23, 2017
    14
  5. Andrea Rovai
    Hi everybody,
    I apologize I'm answering just now.
    To avoid the necessity of powering the screen, as Laura said, you should look for a USB-powered touch screen.
    PeterRobinson likes this.
  6. PeterRobinson
    Feb 23, 2017
    14
    Yes! That is the exact solution we found.
    Now to make a mobile power supply!
  7. Jetguy
    Jetguy Member
    Mar 28, 2017
    65
    60
    I would use a high end custom UPS solution since the rated input voltage to UDOO X86 requires tight regulation and filtering. Automotive systems range from droops of 9V to transients of 15+ Volts and could damage UDOO if driven directly. This is an ideal solution for smooth transient power in an automotive environment. http://www.mini-box.com/OpenUPS2
    Again, in an automotive application, DC power in a vehicle drops as low as 9V during the starter motor usage drawing several hundred amps from a battery, to roughly 16V or higher spikes as charging the battery alone is 14.4V and inductive spikes as relays a solenoids could easily push higher transients. Per the specs http://www.udoo.org/docs-x86/Introduction/Introduction.html
    12V (± 5%) DC Power Jack (standard 5.5mm/2.1mm barrel jack: internal positive)
    5% tolerance on 12V is only ± 0.6V so high input max is 12.6V, minimum is 11.4V
  8. Jetguy
    Jetguy Member
    Mar 28, 2017
    65
    60
    For building some sort of mobile (battery powered computing system) you really minimally should include basic safety features.
    #1 BMS (Battery Management System) prevents over charging and over discharge of Lithium and other types of batteries- Fire prevention!!!
    #2 Battery charging circuit since we are likely talking about a battery chemistry that should be controlled charging to prevent damage and fire
    #3 Since UDOO X86 requires tight 5% regulation at 12V, directly powering from batteries - especially different variants where charging voltage is several volts higher, you need a regulator buck/boost to use the full capacity of many battery combinations. Here is what I would shoot for if I didn't want to engineer all of the those individual requirements and modules.
    http://www.batteryspace.com/12v-132vregulatedbatterypack.aspx
