Bluetooth of UDOO X86 on Xubuntu 16.04.02
Discussion in 'UDOO X86' started by yamikiri, Apr 24, 2017.
  1. yamikiri
    yamikiri New Member
    Apr 24, 2017
    Hi all,
    I've got my UDOO x86 advanced installed xubuntu 16.04.02.
    The wifi is working fine, the bluetooth seems recognized by system, but never detected any device.
    I've searched the keyword "bluetooth" on the forum, there's nothing related.
    Is there anyone who have the same problem?
    Thanks!
  3. yamikiri
    yamikiri New Member
    Apr 24, 2017
    Hi waltervl,
    Thanks for the reply.
    I have no luck with ac3168 bluetooth.
    My final working bluetooth is with additional usb bluetooth dongle.
    And I switched to Ubuntu 16.04.02, with many try-on-error.
    Anyway, finally get it working, thanks!
  4. waltervl
    Using another bluetooth device is not what should be the solution. Anyone elso got bluetooth working on the Intel® Dual Band Wireless Wi-Fi AC and Bluetooth 4.2 module (Intel® AC3168)?
  5. Eric Falsken
    Eric Falsken New Member
    Apr 25, 2017
    19
    I got it working, but I absolutely HAD to have the antenna connected to the AUX connector of the Wifi Card (nearest the corner of the card).
    waltervl and yamikiri like this.
  6. Ianb14
    Ianb14 New Member
    Apr 30, 2017
    I had the same issue but in windows 10, Eric is correct you must put the antenna on the auxiliary output on the AC/ Bluetooth card, now my Bluetooth is working perfect as before the Bluetooth device had to be within 5 inches of the board to connect.
  7. Eckmar
    Eckmar New Member
    May 1, 2017
    but if I put the antenna to the aux output, WIFI is not working correctly. Is there a second antenna missing?
    Alexander Chang likes this.
  8. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    There are dual antenna sets available (Amazon, eBay) with each having a slightly different design for Wi-Fi and Bluetooth. Just be sure they have the tiny Ipex Mhf4 connectors if you are using them with a NGFF M.2 network card.
    waltervl and Alexander Chang like this.
  9. Eckmar
    Eckmar New Member
    May 1, 2017
    In my received package there was only one antenne : RFPCA308_01 Rev.01
    1.) So I don't know - is it for WIFI or Bluetooth
    2.) Where is the second antenna?
    3.) Why is the package not complete after waiting sooooo long? Even screws for the WIFI and SSD are missing.
    lucabelluccini likes this.
  10. lucabelluccini
    lucabelluccini New Member
    May 2, 2017
    I confirm I received only 1 antenna.
  11. Alexander Chang
    Alexander Chang New Member
    Apr 27, 2017
    Does it mean that if I'm going to use wifi and bluetooth at the same time, I'm going to need the second antenna?
    If yes, why isn't it included in the package?
  12. waltervl
    From the Intel FAQ: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005821.html
    Can you use Bluetooth and Wi-Fi radios simultaneously (can they coexist)?
    Bluetooth and Wi-Fi radios share the same frequency band (2.4 GHz). Bluetooth Wireless Technology uses frequency hopping techniques to prevent conflicts from causing wireless connectivity issues. However, when Wi-Fi and Bluetooth radios transmit and receive data in the same frequency band simultaneously, performance may suffer. On Intel Wireless Adapters that support Bluetooth, the main antenna is dedicated to Wi-Fi, but the auxiliary or secondary antenna is shared between Wi-Fi and Bluetooth.
    Markus Laire likes this.
  13. mkopack
    Well, I'll say that when I initially set things up I had the antenna plugged into the AUX port on the Wifi/BT board and I got ZERO wifi signal, but BT worked fine. When I moved it to the Main port on the board Wifi worked fine, and I got basically no BT. Personally I care more about Wifi than BT so I'm going with that setup. But thanks for the info for getting the 2nd antenna if we want it.
  14. waltervl
    Apparently there is a Kickstarter update with more info about missing antennas.
  15. Tooroo
    Tooroo New Member
    May 4, 2017
