Udoo Neo Full not detecting any joysticks with SDL2 / UDOObuntu 2.1.2
Discussion in 'UDOO NEO' started by oxoocoffee, Feb 24, 2017.
Tags:
  1. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Ok so I switched to dummy driver and this time I got this. Still wondering why frame buffer was not detected (separate issue)
    udooer@udooneo:~/github/jstest-sdl$ SDL_VIDEODRIVER=dummy ./jstest-sdl --list
    No joysticks were found
    udooer@udooneo:~/github/jstest-sdl$ ls -l /dev/input/
    by-id/ event0 event2 event4 js1 js3
    by-path/ event1 event3 js0 js2 mice
  2. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    I was just informed on IRC SDL channel that SDL2 does not use jsX. It was used in SDL1. Now SDL2 is using udev/evdev.
    Is there a module that needs to be build or some rule added?
  3. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    You need to add some udev rules for your joystick:
    First find the ID_VENDOR and ID_MODEL of the joystick (change jsX) eg:
    udevadm info -q all -n /dev/input/js0
    create a udev rule file in /etc/udev/rules.d/73-presistent-joystick.rules
    Add an entry for the your ID_VENDOR and ID_MODEL eg:
    KERNEL=="js?", ENV{ID_VENDOR}=="YOUR ID VENDOR", ENV{ID_MODEL}=="YOUR ID MODEL" , NAME="input/js0"
  4. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    Below is info for each jsX. I also added /etc/udev/rules.d/73-presistent-joystick.rules
    KERNEL=="js?", ENV{ID_VENDOR}=="046d", ENV{ID_MODEL}=="c219" , NAME="input/js0"
    After rebooting and plugging my usb joystick It still it is listed as js3. Doing cat js3 and pressing buttons on joystick I get some echo on screen.
    udooer@udooneo:/dev/input$ udevadm info -q all -n /dev/input/js0
    P: /devices/virtual/input/input1/js0
    N: input/js0
    E: DEVNAME=/dev/input/js0
    E: DEVPATH=/devices/virtual/input/input1/js0
    E: ID_INPUT=1
    E: ID_INPUT_ACCELEROMETER=1
    E: MAJOR=13
    E: MINOR=0
    E: SUBSYSTEM=input
    E: USEC_INITIALIZED=779519
    udooer@udooneo:/dev/input$ udevadm info -q all -n /dev/input/js1
    P: /devices/virtual/input/input2/js1
    N: input/js1
    E: DEVNAME=/dev/input/js1
    E: DEVPATH=/devices/virtual/input/input2/js1
    E: ID_INPUT=1
    E: MAJOR=13
    E: MINOR=1
    E: SUBSYSTEM=input
    E: USEC_INITIALIZED=780925
    udooer@udooneo:/dev/input$ udevadm info -q all -n /dev/input/js2
    P: /devices/virtual/input/input3/js2
    N: input/js2
    E: DEVNAME=/dev/input/js2
    E: DEVPATH=/devices/virtual/input/input3/js2
    E: ID_INPUT=1
    E: MAJOR=13
    E: MINOR=2
    E: SUBSYSTEM=input
    E: USEC_INITIALIZED=782143
    udooer@udooneo:/dev/input$ udevadm info -q all -n /dev/input/js3
    P: /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1:1.0/0003:046D:C219.0001/input/input4/js3
    N: input/js3
    S: input/by-id/usb-Logitech_Logitech_Cordless_RumblePad_2-joystick
    S: input/by-path/platform-ci_hdrc.1-usb-0:1:1.0-joystick
    E: DEVLINKS=/dev/input/by-id/usb-Logitech_Logitech_Cordless_RumblePad_2-joystick /dev/input/by-path/platform-ci_hdrc.1-usb-0:1:1.0-joystick
    E: DEVNAME=/dev/input/js3
    E: DEVPATH=/devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1:1.0/0003:046D:C219.0001/input/input4/js3
    E: ID_BUS=usb
    E: ID_FOR_SEAT=input-platform-ci_hdrc_1-usb-0_1_1_0
    E: ID_INPUT=1
    E: ID_INPUT_JOYSTICK=1
    E: ID_MODEL=Logitech_Cordless_RumblePad_2
    E: ID_MODEL_ENC=Logitech\x20Cordless\x20RumblePad\x202
    E: ID_MODEL_ID=c219
    E: ID_PATH=platform-ci_hdrc.1-usb-0:1:1.0
    E: ID_PATH_TAG=platform-ci_hdrc_1-usb-0_1_1_0
    E: ID_REVISION=0200
    E: ID_SERIAL=Logitech_Logitech_Cordless_RumblePad_2
    E: ID_TYPE=hid
    E: ID_USB_DRIVER=usbhid
    E: ID_USB_INTERFACES=:030000:
    E: ID_USB_INTERFACE_NUM=00
    E: ID_VENDOR=Logitech
    E: ID_VENDOR_ENC=Logitech
    E: ID_VENDOR_ID=046d
    E: MAJOR=13
    E: MINOR=3
    E: SUBSYSTEM=input
    E: TAGS=:seat:uaccess:
    E: USEC_INITIALIZED=783143
  5. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    After removing joystick and rebooting udoo board I see that after adding rule I do not see any jsX in /dev/input/
    udooer@udooneo:~$ ls -l /dev/input/
    total 0
    drwxr-xr-x 2 root root 60 Jul 17 11:20 by-path
    crw-r----- 1 root root 13, 64 Jul 17 11:20 event0
    crw------- 1 root root 13, 65 Jul 17 11:20 event1
    crw------- 1 root root 13, 66 Jul 17 11:20 event2
    crw------- 1 root root 13, 67 Jul 17 11:20 event3
    crw-r----- 1 root root 13, 63 Jul 17 11:20 mice
    After plugging in joystick I do get all four js with still js3 as my joystick and event4 added
    total 0
    drwxr-xr-x 2 root root 80 Jul 17 11:41 by-id
    drwxr-xr-x 2 root root 100 Jul 17 11:41 by-path
    crw-r----- 1 root root 13, 68 Jul 17 11:41 event4
    crw-r--r-- 1 root root 13, 0 Jul 17 11:41 js0
    crw-r--r-- 1 root root 13, 1 Jul 17 11:41 js1
    crw-r--r-- 1 root root 13, 2 Jul 17 11:41 js2
    crw-r--r-- 1 root root 13, 3 Jul 17 11:41 js3
    Also here is my dmesg
    [ 16.262651] init: udoofota-server respawning too fast, stopped
    [ 16.574394] libphy: 2188000.ethernet:00 - Link is Up - 100/Full
    [ 16.574427] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 39.832738] systemd-udevd[218]: timeout 'accelerometer /devices/virtual/input/input2'
    [ 39.902943] systemd-udevd[216]: timeout 'accelerometer /devices/virtual/input/input3'
    [ 69.313005] cfg80211: Verifying active interfaces after reg change
    [ 74.847782] init: ttyGS0 main process ended, respawning
    [ 1280.302915] usb 1-1: new low-speed USB device number 2 using ci_hdrc
    [ 1280.628177] usbcore: registered new interface driver usbhid
    [ 1280.628200] usbhid: USB HID core driver
    [ 1280.680062] input: Logitech Logitech Cordless RumblePad 2 as /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1:1.0/0003:046D:C219.0001/input/input4
    [ 1280.680484] logitech 0003:046D:C219.0001: input: USB HID v1.10 Gamepad [Logitech Logitech Cordless RumblePad 2] on usb-ci_hdrc.1-1/input0
    [ 1280.680501] hid_logitech: Force feedback for Logitech force feedback devices by Johann Deneux <johann.deneux@it.uu.se>
  6. jas-mx
    Dec 31, 2013
    407
    118
    You need a line like this:
    KERNEL=="js?", ENV{ID_VENDOR}=="Logitech", ENV{ID_MODEL}=="Logitech_Cordless_RumblePad_2" , NAME="input/js3"
  7. jas-mx
    Dec 31, 2013
    407
    118
    Typo should be:
    KERNEL=="js?", ENV{ID_VENDOR}=="Logitech", ENV{ID_MODEL}=="Logitech_Cordless_RumblePad_2" , NAME="input/js0"
    [/QUOTE]
  8. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    jas-mx
    I did updated my rule to
    after board and plugging in joystick I get data updates on js3 not on js0
    Looks like accelerometer is going before it
    Here is latest dmesg
    [ 17.424239] libphy: 2188000.ethernet:00 - Link is Up - 100/Full
    [ 17.424269] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 39.582748] systemd-udevd[213]: timeout 'accelerometer /devices/virtual/input/input1'
    [ 69.059954] cfg80211: Verifying active interfaces after reg change
    [ 74.404616] init: ttyGS0 main process ended, respawning
    [ 1742.872465] usb 1-1: new low-speed USB device number 2 using ci_hdrc
    [ 1743.196454] usbcore: registered new interface driver usbhid
    [ 1743.196479] usbhid: USB HID core driver
    [ 1743.253417] input: Logitech Logitech Cordless RumblePad 2 as /devices/soc0/soc.0/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1:1.0/0003:046D:C219.0001/input/input4
    [ 1743.253917] logitech 0003:046D:C219.0001: input: USB HID v1.10 Gamepad [Logitech Logitech Cordless RumblePad 2] on usb-ci_hdrc.1-1/input0
    [ 1743.253942] hid_logitech: Force feedback for Logitech force feedback devices by Johann Deneux <johann.deneux@it.uu.se>
  9. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    I think these are the guys js0-js2
    udooer@udooneo:/sensors$ ls -l
    total 0
    lrwxrwxrwx 1 root root 39 Jul 18 12:14 accelerometer -> /sys/class/misc/FreescaleAccelerometer/
    lrwxrwxrwx 1 root root 35 Jul 18 12:14 gyroscope -> /sys/class/misc/FreescaleGyroscope/
    lrwxrwxrwx 1 root root 38 Jul 18 12:14 magnetometer -> /sys/class/misc/FreescaleMagnetometer/
    Also from dmesg
    [ 7.648747] input: FreescaleGyroscope as /devices/virtual/input/input1
    [ 7.651150] fxas2100x device driver probe successfully
    [ 7.658565] input: FreescaleAccelerometer as /devices/virtual/input/input2
    [ 7.660400] input: FreescaleMagnetometer as /devices/virtual/input/input3
    Could they be remaped to other js or disabled since I am not using them at the moment?
  10. jas-mx
    Dec 31, 2013
    407
    118
    The udev rule should have replaced js0 with your joystick so you will need to debug why its not working. If you want to disable the acclerometer/gyroscope then you need to disable then from the dts file or create udev rules to stop them being mapped.
  11. oxoocoffee
    oxoocoffee Member
    Sep 13, 2016
    57
    I will look into disabling it in udev. Could you also expand on "debugging" Where would you start and what to look for as a start point?
    Anything you can think of. I will try to find what the issue might be. I never done this so it is great time to learn.
    Thank you
