hdmi cec compile
Discussion in 'UDOO X86' started by drc85, Jan 11, 2018.
  1. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    Try whereis cec-ctl - that checks several locations where files can be installed.
    Some possible locations are /usr/bin /bin /usr/sbin* /usr/sbin* (Two last ones will generally only work when running command as root user.)
    drc85 likes this.
  2. Markus Laire
    Mar 9, 2017
    225
    91
    Another useful command which lists files actually installed by a package (only works for packages you have installed):
    dpkg-query -L PACKAGE
    So try:
    dpkg-query -L v4l-utils
    dpkg-query -L cec-utils
    drc85 likes this.
  3. drc85
    drc85 Member
    Dec 30, 2017
    45
    thanks for your help, i will try when i get back home.
    did you was able to get the hdmi cec working on linux?
    also what about infra red is it working? or do i need to compile and load module also? i have a universal remote laying around and thought about using it with the udoo till i get cec to work :D
  4. Markus Laire
    Mar 9, 2017
    225
    91
    I havn't tried to get CEC or IR working myself.
    drc85 likes this.
  5. drc85
    drc85 Member
    Dec 30, 2017
    45
    ok udo is showing a working example on the blog... it somehow is possible :D
  6. LDighera
    LDighera UDOOer
    Jan 13, 2014
    206
    36
    I presume you are referring to this blog post. It refers to this Udoo X86 Documentation page.
    Are there any corrections or additional information you may be able to provide, as a result of your apparently successful CEC implementation, to supplement the instructions on the doc page?
    Thank you for sharing your CEC implementation effort for the benefit of other Udoo X86 users.
  7. drc85
    drc85 Member
    Dec 30, 2017
    45
    i didnt really do much, im really a linux newbie :D
    here are the instructions for compiling the seco-cec.ko module.
    they are a little bit diffrent from the blog post. because of diffrent root rights or diffrent ubuntu distribution...
    im not sure why its diffrent.. maybe its also not the right way i did id
    im on linux mint 18.4
    i installed kernel ukuu ( easy gui for updating the kernel)
    then i updatet to 4.14.0 (i tried the 4.14.14 too but it dont worked to compile
    enter bash:
    1-sudo apt install git build-essential linux-headers-`uname -r` (install files to main user folder)
    2-cd secocec (go to secccec folder)
    3-make (compiles the module seco-cec.ko)
    close bash
    then u have the module compiled and it should be inside the main user folder
    after that i used
    enter bash:
    1-sudo modprobe -v cec (mount cec main module)
    3-sudo insmod seco-cec.ko (mount seco-cec.ko module)
    4-lsmod (to check if CEC and seco-cec.ko modules are running and mounted)
    close bash
    i didnt got any further i will try tonight if i can get cec-ctl running
    LDighera likes this.
  8. drc85
    drc85 Member
    Dec 30, 2017
    45
    im also testing some methods to get hdmi cec working on the windows10 i also have installed...
    there are a few programms.
    evenghost: i think it is for ir remotes
    and libcec: this is for cec (im not sure u need the pulse eight adapter if ur hdmi suppurts cec)
    but i didnt got any further because i cant install netframwork 3,5 :(
    at the moment i wouldnt care if i run linux or windows to get kodi to work with the cec tv remote...
  9. icce
    icce New Member
    Mar 13, 2016
    16
    After finish all steps from Remote Control, I tried ```cec-ctl``` and it returned:
    Failed to open /dev/cec0
    It seems like something wrong here?
