[SOLVED] Using HDMI>VGA convertor, how to change resolution
Discussion in 'Troubleshooting' started by gediminas, Nov 21, 2013.
  1. gediminas
    gediminas New Member
    Nov 21, 2013
    I have connected a HTMI to VGA converter to my UDOO, and connected to my 1280x1024 VGA monitor.
    Works fine except that it keeps using 1920x1080 resolution. I have tried to add my resolution manually but when I try to change to it, it says that my minimum resolution is 1920x1080 and doesn't allow to do that. Below is output from xrandr:
    ubuntu@imx6-qsdl:~$ xrandr
    xrandr: Failed to get size of gamma for output default
    Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
    default connected 1920x1080+0+0 0mm x 0mm
       1920x1080      60.0*
    How to change minimum resolution to something smaller?
    Thanks in advance,
    Gediminas
  2. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Re: Using HDMI>VGA convertor, how to change minimum resoluti
    Hi
    I solved a similar problem changed the resolution at boot with
    setenv setvideomode 'setenv videomode video=mxcfb0:dev=hdmi,1024x768@60,bpp=32'
    You can find more info at this topic viewtopic.php?f=16&t=193&start=30
    Regards
  3. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Yep, you may need to override a couple of Environmental variables at boot time.
    (Team UDOO are working on display/resolution issues of course, so this is an interim solution).
    Note: HDMI -> whatever adapters can have their own problems.
  4. gediminas
    Nov 21, 2013
    It worked. Thanks!
  5. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Great! Can we add [SOLVED] to the topic title?
