External GPS modual
Discussion in 'Android' started by MrJunix, Nov 19, 2013.
  1. MrJunix
    MrJunix New Member
    Oct 29, 2013
    GPS modules are fairly common in the DIY/ hobbyist electronics world. I listed some easily obtainable examples below. I have sent, and there are many examples available online of how to send, GPS positioning into your Arduino sketches.
    So my question, to the android experts here, how difficult is it to send GPS data from one of these hobbyist GPS units into the android system so the Android API can feed it to apps? http://developer.android.com/reference/ ... tatus.html
    Best I can figure out, Read GPS with Arduino sketch, Send to Android over shared serial, interpret GPS with custom APK, APK published its self as a mock location provider. Hoping for a more integrated solution. Are there any location providers as is? If I compile it into the android image, can it be an official location provider, rather than a mock location provider? I am not anything close to an Android expert.
    List of GPS units for hoddyist:
    http://www.adafruit.com/products/98
    https://www.sparkfun.com/products/10710
    https://www.sparkfun.com/products/9891
    https://www.sparkfun.com/products/10920
    http://www.adafruit.com/products/746
    http://www.adafruit.com/products/1059
  2. andcmp
    andcmp New Member
    161
    Instead of an Arduino compatible GPS shield/module, why don't you consider an usb, or even better a bluetooth, GPS module? This way you should be able to read GPS data directly from Android.
  3. MrJunix
    MrJunix New Member
    Oct 29, 2013
    Accepting GPS location from a bluetooth GPS still requires the enable Allow Mock Locations in Setting and an android app, like Bluetooth GPS from GG MobLab http://goo.gl/5J1ccj , to inject the location data.
    I do not have access to a USB gps module, have you tested one with Android? Was the location data accepted without enabling Mock Locations? Have you tested it with the Udoo board?
  4. abuthoppan
    abuthoppan New Member
    Dec 3, 2013
    How can we access the GPS data from the GPIO and use it in the android? I am confused..
  5. abuthoppan
    Dec 3, 2013
    I have a usb gps module. I connected it and nothing happens normally. I think I will need to write own driver for the same. Is there any shortcuts????
  6. Arbies
    Arbies New Member
    Dec 16, 2013
    The BU-353 is a fairly well used USB GPS module.
  7. abuthoppan
    Dec 3, 2013
    Cool… I did it.. I connected an USB GPS device and written a driver app for android..
  8. eric
    eric New Member
    Nov 21, 2013
    26
    abuthoppan, any chance you want to share more information? Which module, your driver, does it work in all apps like any normal GPS receiver would?
  9. dzondo
    dzondo New Member
    Feb 7, 2014
    28
    Please abuthoppan be so kind and share some more information about how to run that GPS. Do you use that BU-353 model?
  10. andcmp
    andcmp New Member
    161
    If you would like to share your work, it would be really appreciated!
  11. dzondo
    dzondo New Member
    Feb 7, 2014
    28
  12. bhakta
    bhakta New Member
    Nov 22, 2013
    16
    Can you provide details? I'd like to do this with a USB Mic and possibly other devices like webcam, etc.
    TIA
  13. dzondo
    dzondo New Member
    Feb 7, 2014
    28
    still nothing about runing usb GPS on UDOO?? :(
  14. peter247
    peter247 New Member
    Mar 10, 2014
    263
    My last table was advent vega running Android , which didn`t have a gps built in , and wanted so I could use it with google maps etc.
    The way I did it was via bluetooth and a bluetooth gps.
