SATA cable connector name?
Discussion in 'General Discussion' started by weemo, Nov 28, 2013.
  1. weemo
    weemo Member
    Nov 15, 2013
    31
    I am trying to find the sata cable locally. What is the name of the cable end to the board???
    Thanks
  2. firehopper
    firehopper Member
    Jun 10, 2013
    154
    if you search for a sata data cable. that should get you what you need
    its not really a cable you can build yourself
  3. weemo
    weemo Member
    Nov 15, 2013
    31
    Geez, thought the onboard connector was different, sorry for the unnecessary post and thanks
  4. firehopper
    firehopper Member
    Jun 10, 2013
    154
    oh your refering to the sata power, j12? its called a jst 2pin
    it can be aquired from lots of places.. ebay is one such place..
  5. tibmeister
    tibmeister New Member
    Oct 20, 2013
    19
    So this is about the only cable I can find that would interface a SATA power to a JST connector, and it's nifty that it also has a SATA interface on the same connector, and it's a right-angle connector. The drawback is the minimum order is 300 pcs, so that puts it out of reach of most folks unless the folks behind Udoo get a batch of these and re-sale them here on the site as an added accessory.
    http://sshly.en.alibaba.com/product/357 ... _4PIN.html
