DallasTemperature and OneWire
Discussion in 'Arduino IDE' started by imouro, Nov 11, 2013.
  1. imouro
    imouro New Member
    Oct 23, 2013
    Hi!
    I write one sketch this for test:
    #include <OneWire.h>
    #include <DallasTemperature.h>
    #define ONE_WIRE_BUS 40
    OneWire oneWire(ONE_WIRE_BUS);
    DallasTemperature sensors(&oneWire);
    void setup(void) {
    Serial.begin(9600);
    Serial.println("Dallas Temperature IC Control Library Demo");
    sensors.begin();
    void loop(void) {
    Serial.print("Conected...");
    sensors.requestTemperatures();
    Serial.println("OK");
    Serial.print("Temperature: ");
    Serial.print(sensors.getTempCByIndex(0));
    I import the libraries OneWire and DallasTemperature for Ardunio 1 in /home/ubuntu/Arduino/libraries
    When i see the serial Monitor I can not see nothing.
    If I comment the lines of sensors, the serial monitor show "conected .. OK. Temperature"
    In MEGA Ardunio this code works perfectly. Any suggestions?
    Thanks!
  2. imouro
    imouro New Member
    Oct 23, 2013
    any idea?
  3. delba
    Try using the Arduino DUE libraries. It has a different architecture than the Arduino UNO or Mega.
  4. marcinozog
    marcinozog New Member
    Nov 1, 2013
    I have the same problem, in my case i have a problem with float variables, e.g.
    void setup() {
    float f = 0.1;
    Serial.println(f);
    it crashes my ardu in udoo, when i replace float to int in DallasTemperature then it work, sometimes when i use sprintf then crash it, sorry for my en
  5. simcode
    simcode New Member
    Dec 2, 2013
    I have the same problem.
    if i use Serial.println then stop process
  6. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Correction to my earlier post.
    The 'Serial' library is documented as supporting "any data type" (not sure they mean that literally, but for sure Strings and Floats are supposed to work out of the box). Clearly it doesn't.
    Here is an example of a workaround - use an array of chars with a Null terminator.
    char myTestString [ ] = "Test string\0";
    Serial.println(myTestString);
  7. simcode
    simcode New Member
    Dec 2, 2013
    thank you.
    but i don't run.
    if i use Serial library then stop process
  8. nicoj10
    nicoj10 New Member
    Jan 11, 2014
    i have the same problem (no output on serial with those libraries) and i hope it gets fixed soon. I don't understand why it works on my normal Due and not on the UDOO. I don't know how to change my code in order to make it work.
    #define ONE_WIRE_BUS 3
    int led_temp = 9;
    DeviceAddress Thermometer_1 = {0x28, 0xF9, 0xE2, 0x20, 0x05, 0x00, 0x00, 0xE6};
    void setup() {
      Serial.begin(9600);
    pinMode(led_temp,OUTPUT);
      sensors.begin();
      // Einstellung der Aufl?sung auf 10 bit
      sensors.setResolution(Thermometer_1, 10);
    void loop() {
      float Temperatur_1 = sensors.getTempC(Thermometer_1);
      Serial.print("0");
      Serial.print("#");
      Serial.println(Temperatur_1);
        if(Temperatur_1>23)
          digitalWrite(led_temp,HIGH);
        else
          digitalWrite(led_temp,LOW);
        delay(1000);
  9. Miika
    Miika New Member
    Jan 26, 2014
    I've tried pretty much every trick in the book to get anything with onewire.h or dallastemp.h libraries to work but I'm always greeted with
    errors
    In file included from one_wire_address_finder.pde:7:0:
    /opt/arduino-1.5.4/libraries/OneWire/OneWire.h:77:2: error: #error "Please define I/O register types here"
    /opt/arduino-1.5.4/libraries/OneWire/OneWire.h:84:5: error: 'IO_REG_TYPE' does not name a type
    /opt/arduino-1.5.4/libraries/OneWire/OneWire.h:85:14: error: 'IO_REG_TYPE' does not name a type
    I've tried different library versions and so forth but so far no luck. On Windows 7 computer with arduino 1.0.5 and 1.5.5 rc2 everything works just fine.
    What the heck is wrong with the udoo arduino ide?
  10. acsabir
    acsabir New Member
    Mar 28, 2014
    Try updating OneWire and DallasTemperature libraries to most recent one. That worked for us.
