1-Wire support
Discussion in 'UDOO QUAD' started by Ewald Harmsen, Mar 22, 2017.
  1. Ewald Harmsen
    Ewald Harmsen New Member
    Feb 19, 2016
    12
    Hi All,
    I have a DS18B20 waterproof temperature sensor.
    I connect it to 3.3 Volt, ground and PIN 7, GPIIO 42, with a 4.7 KOhm resistor between + and data
    The sensor is working on a ESP8266 module, but I want to connect it directly to my Udoo.
    How can I add this 1-wire device and read the values of it?
    I try to add it to Domoticz.
    ManicLalo likes this.
  2. ManicLalo
    ManicLalo New Member
    Sep 29, 2016
    Did you ever figure it out? I've been trying to figure it out myself
  3. waltervl
  4. fetcher
    fetcher Member
    Mar 9, 2014
    166
    If you want to read your 1-wire sensors from the Linux i.MX6 side rather than from the Arduino SAM3x, there is a nice package called 'owfs-fuse' (ows = "one-wire file system") available in the Debian and Ubuntu repositories-- just do "apt-get install owfs-fuse" to install. This presents all detected Dallas 1-wire sensors as virtual filesystem objects, organized by their device-type byte and ROM serial number.
    root@imp:~# ls -l /1w
    total 0
    drwxrwxrwx 1 root root  8 Nov 19 02:39 26.4D2615000000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 26.C74E15000000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.570F32050000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.A15A31050000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.B4A831050000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.D3D131050000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.FF1A6E221703
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.FF7FC0711703
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.FFB4AF711703
    drwxrwxrwx 1 root root  8 Nov 19 02:39 28.FFC962221703
    drwxrwxrwx 1 root root  8 Nov 19 02:39 29.D3200C000000
    drwxrwxrwx 1 root root  8 Nov 19 02:39 29.FA3600000000
    drwxr-xr-x 1 root root  8 Nov 18 23:59 alarm
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.1
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.2
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.3
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.4
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.5
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.6
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.7
    drwxr-xr-x 1 root root  8 Nov 18 23:59 bus.8
    drwxr-xr-x 1 root root  8 Nov 18 23:59 settings
    drwxrwxrwx 1 root root  8 Nov 19 02:39 simultaneous
    drwxr-xr-x 1 root root  8 Nov 18 23:59 statistics
    drwxr-xr-x 1 root root 32 Nov 18 23:59 structure
    drwxr-xr-x 1 root root  8 Nov 18 23:59 system
    drwxr-xr-x 1 root root  8 Nov 18 23:59 uncached
    They can be read very easily from shell scripts or other code. e.g.
    root@imp:~# cat /1w/28.FF1A6E221703/temperature ; echo
            64.4
    Besides plain 18B20's, it knows about DS2438-based humidity sensors, DS2406+TAI8570 barometric pressure sensors, DS2408 8-bit PIO chips, and just about everything else Dallas/Maxim has ever made.
    Although there is a software-based Linux 1wire driver now, I connect my sensors via I2c using a DS2482-800 chip behind a 3.3V-5V level converter, since some are 5V-only and/or on long cables, and I need the extra noise-resistance and bus isolation provided by this iC. It also reduces CPU load by taking over the more time-critical 1wire communication tasks. With this hardware, I invoke the owfs daemon from /etc/rc.local as
    /usr/lib/owfs/owfs -c /etc/owfs.conf --i2c=/dev/i2c-0:ALL -F /1w
    And my owfs.conf contains
    server: device = /dev/i2c-0
    mountpoint = /1w
    allow_other
    server: port = localhost:4304
    error_print=1
    error_level=3
    although I'm not sure whether that file is really necessary; it didn't exist when I first started using owfs, some years ago.
    The -F parameter gives temperature readings in Fahrenheit, rather than the default Celsius. If you prefer Celsius, just leave this off.
    If you want to connect 1-wire devices directly to an Udoo pin, this is supported by owfs now, using --w1 rather than --i2c as above, but you'll first need to reconfigure your Udoo's device tree to change the desired pin from a GPIO, letting the 1-wire driver take it over instead. This can be done using Udoo's provided dtweb utility (easiest), or by manually editing your .dts file and recompiling it with dtc.
    waltervl likes this.
