Some prelim V8 (v1605B findings)
Discussion in 'UDOO BOLT' started by ccs_hello, Apr 15, 2019.
  1. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Received my BOLT V8 today (US tax day :( :( .)
    Inside the box there is the BOLT SBC in anti-static bag and is well protected by forms on all 4 sides.
    Added the 4GB DDR4 SODIMM (mine is 2133MHz type.)
    Try the 20V DC in jack (4.0mm x 2.9mm x 1.0mm center pin),
    only outer ring (negative) and inner ring (positive) are used by BOLT. Center signal pin (the 1mm one) is not used. This is the standard power supply plug found in some recent laptops.
    I use this one from eBay (search 183301986663 ), total cost is $11, shipping included.
    On USB-C based power supply:
    I tried my 45W PD battery pack (which can supply 20V 2.25A) but BOLT's USB-C won't activate it (it only want to talk to a 60W 20V 3A PD power source, not 45W.)
    I tried an AC-DC USB-C PD power supply used by recent Macbook Pro (known as Apple 61W, model number A1718) that will work as USB-C based power supply.
    I tried other AC-DC 45W PD (can do 20V 2.25A) power adapters but they will not work.
    I.e., 60W PD (20V 3A) is essential.
    evaloverde and LDighera like this.
  2. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    More notes: I used the HDMI port closest to the corner. My single DDR4 SODIMM is closest to the fan. Fan came up fairly frequently (and is a bit noisy.)
    Note when first time power the board up, it took more than 1 minute to see some meaningful activities. I think it's BIOS configuration initialization activity. The eMMC is a DF4032. It seems that it's blank.
    I do not see UEFI shell anywhere. So without any bootable device, BIOS setup screen will always show up.
    (In BIOS menu, some of the Ryzen BIOS configuration items are foreign to me. I am more familiar with Intel based BIOS config.)
    When I initially plug in the 20V power, the power consumption is around 20.4V 0.05A (a little bit over 1 W.)
    When I loaded OS (I tried Ubuntu 16.04 LTS and installed on a key B+E SATA 512GB SSD on key-B slot), the power consumption varies (without stress testing, it can go as high as 20V 1.7A and as low as 20V 0.7A.)
    After I shutdown the Linux OS, I observed the power consumption as 20V 0.033A (0.66 W.)
  3. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    I only tried Ubuntu 16.04 LTS. It cannot find the graphics card driver so I am stuck at 800x600 VGA driver mode resolution.
    The default install also cannot find eMMC as a possible target installation candidate (no driver loaded.)
    (I also live-upgraded to 18.04 LTS, the graphics driver is also not found. Not only that, without changing the boot flag, the Linux GUI screen won't show up.)
  4. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    It would be helpful that UDOO puts the drivers in a site for download.
    It is rather inconvenient/difficult to get the drivers from AMD (need to create developer's account, etc.)
    LDighera likes this.
  5. gleveque69
    gleveque69 New Member
    May 11, 2017
  6. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
  7. gleveque69
    May 11, 2017
  8. LDighera
    LDighera UDOOer
    Jan 13, 2014
    206
    36
    Thank you for providing all your firsthand information on the new Udoo Volt (I presume V8). What is your guess as to the suitability of this 90 Watt power supply: https://www.ebay.com/itm/173005451394 ?
    Approvals CE,FCC
    100% OEM Compatible
    Over-charge protection
    Short Circuit Protection
    Over Voltage Protection
    Electromagnetic Compatibility
    Input: AC 100V - 240V 50-60Hz
    Input Connecter standard:2 pin
    DC Output: 19.5V 4.62A 90W
    Connecter size: 7.4mm*5.0mm (ref to the picture).
    4Line regulation (full load): ±0.5%
    Peak- to -peak ripple: Working temperature: 0-35℃@100%,50℃@70% load
    Setup rise hold up time: 100ms,50ms,20ms.240VAC input
    Strong made totally compatible part
    Over voltage protection: 115%-135% rated output voltage
    Withstand voltage: I/P-O/P 3Kvac,1 minute
    Over load protection: 115%-135% fold back current limiting,Auto-recovery​
  9. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    The tip size is incorrect.
    This ebay item 113553773925 is a flavor of tip converter (but still not the type for your ebay link.)
    Use my link: "I use this one from eBay (search 183301986663 ), total cost is $11, shipping included"
    to find an equivalent one that is shipped from US.
  10. LDighera
    LDighera UDOOer
    Jan 13, 2014
    206
    36
    Thanks. This tip converter looks to be the correct adapter for the power supply I suggested: https://www.ebay.com/itm/152851311981.
    I understand, but the power supply I suggested is rated at 90 Watts, as is this one: https://www.ebay.com/itm/172255258165 . Given the your lack of success with the 45 Watt supply you tired, I'm thinking that 60 Watts is the minimum power the V8 will accept, so 90 Watts may provide a bit of useful headroom.
    On the other hand, apparently the V8 and power supply are able to communicate their needs and specifications, so perhaps the V8 may reject the 90 Watt supply in favor of a 60 Watt supply as it apparently did with the 45 Watt supply you tired. Thoughts?
  11. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Not sure what your plan is on the power supply. Key is the final DC plug is the 4.5 x 3.0mm type (with an optional center pin.)
    This avoids USB-C PD negotiation altogether.
    Re: USB-C PD negotiation
    Over spec is fine. Under spec (e.g., 45W PD, can output up to 15V, etc.) is not.
  12. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    BOLT's PCIe bus mapping (as seen in Windows 10)
    LDighera and waltervl like this.
  13. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    USB mapping (in Windows 10)
  14. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Small update on USB-C CN8 and CN9 sockets.
  15. Hey Blud
    Hey Blud UDOOer
    May 5, 2020
    Hi! How do I get this to show in Windows to check which is missing a driver? Thank you.
  16. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    These diagrams are to show BOLT's internal hardware mappings, after device drivers are loaded successfully.
    To deal with missing software device driver in Windows, standard Microsoft tool such as Control Panel > Device Manager is still the recommended tool to use.
  17. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    I used a USB-C debugger to check BOLT's USB-C port's output (as PD souring) capability.
    CN8 (the USB-C port nearest to Ethernet port) is labeled (per PD protocol transaction) as 5V 3A 15W capable, No other capabilities exist nor it supports QC2, QC3, and other classic USB powering scheme.
    CN9 is similar with CN8 except that it is only rated/capable for PD Source 5V 1A 5W.
    Zgembo likes this.
  18. David Burrows
    David Burrows UDOOer
    Jun 16, 2020
    Nigel Brown and rdslw like this.
  19. PackElend
    PackElend UDOOer
    Dec 8, 2018
    35
    have you done any speed tests?
    I would like to know if speed can be reached according to USB 3.1 specification at any port, even if all ports are occupied.
    A summary of what is shown in the pictures:
    1. CN8: USB 2.0 & USB 3.2 Gen 2×1 USB 3.1 Gen 2 (old wording: USB 3.1) / USB-C
    2. CN9: USB 2.0 & USB 3.2 Gen 2×1 USB 3.1 Gen 2 (old wording: USB 3.1) / USB-C
    3. CN21: USB 2.0 & USB 3.2 Gen 2×1 USB 3.1 Gen 2 (old wording: USB 3.1) / USB-A
    4. CN22: USB 2.0 & USB 3.2 Gen 2×1 USB 3.1 Gen 2 (old wording: USB 3.1) / USB-A
    5. Arduino: USB 1.1
    6. Key-E: USB 2.0 or 1.1
    correct?
  20. PackElend
    PackElend UDOOer
    Dec 8, 2018
    35
    have you tested the USB-C Hub as well?
