http://pastebin.com/6FMwPg8t No error at the end, but reading back there is a fatal error at line 558. Hard to tell success from failure. if it has failed, would anyone care to speculate where the problem lies?
Your running your make with the -j option (multiple jobs). If you remove the -j option or set it to 1 then the build will fail at the first error encountered.
That explains it, I guess. Still no closer to figuring out how to get the compile to work. Is there a step-by-step guide anywhere, starting from a fresh git clone?
