Sata cable data + power
Discussion in 'UDOO 101' started by dbaron, Jan 1, 2014.
  1. dbaron
    dbaron New Member
    Aug 20, 2013
    Hi everybody.
    Fisrt, happy new year to every body.
    I would like to know when I can find cable to connect an HDD SSD on board (data + power, on connectors J12 and CN9, right?)
    Thanks in advance
    Dominique
  2. mkopack
    Ok, you have a couple options here:
    1) buy the starter kit with all the cables from Udoo (easiest)
    2) Buy a couple cables with the right connectors and splice them together (mainly the power) - not too bad but requires a little soldering or at least some wire crimping.
    3) Buy all the parts to make the power cable from scratch (hardest).
    If you want to do #2 of #3, look at this thread for part information (I recommend doing option #2 if you aren't doing to do #1...):
    viewtopic.php?f=22&t=123
  3. dbaron
    dbaron New Member
    Aug 20, 2013
    Thanks you for your answer.
    I am surprise, because I ordered a Quad UDOO, with all the cables, but I received only an usb cable, SD card, and power adaptor.
    Should I receive a cable for SATA too ?
  4. mkopack
    No the cables are part of other cable bundles. They don't include it as the Dual units don't support SATA and they figured most people would just run off SD... It's really not hard to make the needed cable using what I showed above (option 2) and that way you can get exactly what you want/need.
    Just remember, this doesn't supply 12V, so you need to be sure your SATA drive doesn't need 12V (most of the 3.5" drives tend to, most 2.5 SSD drives don't though and I highly recommend getting a small-ish SSD for this so you get all the benefits of no moving parts, high speed, and lower power draw.)
  5. malaga
    malaga UDOOer
    Jun 19, 2018
    can i buy a SATA cable or do i need to create it on my own...
