I have plugged in my UDOO NEO to my PC and unable get any pop up as stated in UDOO NEO docs regarding driver error. And I am unable to upload my sketch to udoo neo for my external pc. Please help.
I suppose you are using a windows PC? please check the Windows TAB/section on the following Page: https://www.udoo.org/docs-neo/Basic_Setup/Usb_Direct_Connection.html
I have checked it already. They mentioned that an error will pop up and then to update driver. But in my case i am using udoo neo with android booted i am able to access memory by using general file transfer option in android in USB connection so driver error is not popping up for me. So therefore i am unable to upload my sketch to udoo arduino.
Aha, Android! Well that is something completely different. Check the forum because there a some topics about Android for Neo but it is not that sofisticated as Udoobuntu. I do not think this is direct function is working in Android.
for programming the Arduino on Android Neo see https://www.udoo.org/android-udoo-neo-heres-updated-image-arduino-interactions/ and the forum topic with some more instructions: https://www.udoo.org/forum/threads/programming-arduino-sketch-android-app.5026/
Thank You for the reply. I installed the android boot given in the discussion and also tried installing Udoofota but nothing works can you give me a working method to upload sketch to arduino.
Sorry, Android on Neo is very experimental. The given discussion is the only proof it works. Perhaps explain your situation there.
