external USB drive not mounting
Discussion in 'Troubleshooting' started by arjxbh, Jan 20, 2014.
  1. arjxbh
    arjxbh New Member
    Jan 20, 2014
    I have an external USB drive that I had working perfectly fine with my raspberry pi, and now I want to use it with my udoo. I setup an SD card with ubuntu 12.04 on my udoo quad, and now I'm trying to mount the NTFS partitioned drive. I have the following issue:
    arjun@udoo:~$ sudo fdisk -l
    Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes
    255 heads, 63 sectors/track, 966 cylinders, total 15523840 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk identifier: 0x000c356e
            Device Boot      Start         End      Blocks   Id  System
    /dev/mmcblk0p1           16065    14201459     7092697+  83  Linux
    Note: sector size is 4096 (not 512)
    Disk /dev/sda: 3000.6 GB, 3000558944256 bytes
    255 heads, 63 sectors/track, 45599 cylinders, total 732558336 sectors
    Units = sectors of 1 * 4096 = 4096 bytes
    Sector size (logical/physical): 4096 bytes / 4096 bytes
    I/O size (minimum/optimal): 4096 bytes / 4096 bytes
    Disk identifier: 0x000246c6
    /dev/sda1             256   653442047  2613767168    7  HPFS/NTFS/exFAT
    /dev/sda2       653442048   732558335   316465152    7  HPFS/NTFS/exFAT
    arjun@udoo:~$ sudo mount -t ntfs-3g /dev/sda1 /media/mybook
    FATAL: Module fuse not found.
    fuse: device not found, try 'modprobe fuse' first
    arjun@udoo:~$ sudo modprobe fuse
    arjun@udoo:~$ sudo apt-get install fuse
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    fuse is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
    arjun@udoo:~$
    what exactly is fuse and why isn't it working? when I do
    it insists that It is "already the newest version" while
    sudo modprobe fuse
    says that it can't find the module "fuse".
    What's going on here?
  2. arjxbh
    arjxbh New Member
    Jan 20, 2014
  3. mert
    mert UDOOer
    Oct 20, 2013
    10
    FUSE needs to be in the Kernel and it is not... When I have time I'll compile the Kernel with all the necessary modules included in. If someone beats me to it I'll be happy to use it :)
  4. arjxbh
    arjxbh New Member
    Jan 20, 2014
    Thanks! I had the same issue w/ Ubuntu 11 and 12. Ended up using Wheezy and that worked for me. I'd be happy to switch back to Ubuntu though! :D
