NVME M.2 SSD Compatibility List
Discussion in 'UDOO BOLT' started by Chad Ringstrom, Apr 17, 2019.
  1. OlivierP
    OlivierP UDOOer
    Mar 15, 2020
    Under bios I see my WDS100T3X3C recognised under NVME. He sees the right size. How do I make it in the boot menu?
  2. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    You are on the right track. That is, the NVMe drive is ready to be used by the OS installer to install Operating System on to it.
    On the other hand, the UEFI (the new BIOS) is very smart, It will not show any drive/partition in the selection, if that drive/partition is not bootable.
    So, please be patient. Install the OS first, during the installtion, the installer will ask where the OS will reside (such as onto NVMe).
    After a "successful" OS installation, upon reboot, the boot selection menu will show the newly installed OS.
    Jason Gordon likes this.
  3. OlivierP
    OlivierP UDOOer
    Mar 15, 2020
    Thanks. I'm installing windows as we speak.
  4. sunnywilson09
    sunnywilson09 New Member
    Apr 14, 2020
    I am using
    Sabrent 512GB Rocket NVMe PCIe M.2 2280 Internal SSD High Performance Solid State Drive (SB-ROCKET-512)
  5. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I have a Seagate Firecuda 1TB NVMe m.2 drive in my UDOO Bolt. It works great!
    8-Dale
  6. BorisM2A
    BorisM2A New Member
    Jul 3, 2020
    Hello,
    I bought a Transcend TS1TMTE220S and I cloned my Ubuntu 20.04 LTS from my previous Sata SSD Samsung EVO something using this page:
    https://www.linux.com/training-tutorials/clone-your-ubuntu-installation-new-hard-disk/ and it worked.
    sudo smartctl -d nvme -i /dev/nvme0n1
    smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.0-39-generic] (local build)
    Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Model Number: TS1TMTE220S
    Serial Number: F858620045
    Firmware Version: 42B4SAUA
    PCI Vendor/Subsystem ID: 0x126f
    IEEE OUI Identifier: 0x000000
    Controller ID: 1
    Number of Namespaces: 1
    Namespace 1 Size/Capacity: 1 024 209 543 168 [1,02 TB]
    Namespace 1 Utilization: 1 000 149 762 048 [1,00 TB]
    Namespace 1 Formatted LBA Size: 512
    Local Time is: Fri Jul 3 23:25:11 2020 CEST
    mo@mo-C40:~$ sudo smartctl -A /dev/nvme0n1
    [sudo] Mot de passe de mo :
    === START OF SMART DATA SECTION ===
    SMART/Health Information (NVMe Log 0x02)
    Critical Warning: 0x00
    Temperature: 44 Celsius
    Available Spare: 100%
    Available Spare Threshold: 10%
    Percentage Used: 0%
    Data Units Read: 66 969 [34,2 GB] Bolt-NVMe.jpg
    Data Units Written: 1 973 458 [1,01 TB]
    Host Read Commands: 273 518
    Host Write Commands: 7 731 639
    Controller Busy Time: 35
    Power Cycles: 10
    Power On Hours: 3
    Unsafe Shutdowns: 2
    Media and Data Integrity Errors: 0
    Error Information Log Entries: 0
    Warning Comp. Temperature Time: 0
    Critical Comp. Temperature Time: 0
    Thermal Temp. 1 Transition Count: 2
    Thermal Temp. 1 Total Time: 2055
    mo@mo-C40:~$ sudo hdparm -tT /dev/nvme0n1
    /dev/nvme0n1:
    Timing cached reads: 21882 MB in 2.00 seconds = 10956.18 MB/sec
    HDIO_DRIVE_CMD(identify) failed: Inappropriate ioctl for device
    Timing buffered disk reads: 6410 MB in 3.00 seconds = 2136.37 MB/sec
    Hope This Helps
  7. sulewski
    sulewski UDOOer
    Dec 18, 2019
    Hello!
    Any experience with Patriot 1TB M.2 PCIe NVMe Viper VPN100?
    In my case it causes Bolt to power off once in a while. Usually once in 1-2 days. What could be the cause? Power supply is 90W Power Jack and SSD drive works well with other devices.
  8. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    General info for many NVMe SSDs:
    These NVMe devices generate tremendous amount of heat. Adding a heatsink (heat spreader) and keep it cool is a must.
  9. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Have you disabled the eMMC drive in Windows Device Manager? If not this can cause unexpected crashes in Windows, particularly when the system is idle.
  10. sulewski
    sulewski UDOOer
    Dec 18, 2019
    Patriot VPN100 comes with own heatsink. I also monitored drive temperature and it was always normal during shut downs.
    I use Ubuntu 20.04, do I have to set up anything special? I use the onboard eMMC as the system drive and NVMe SSD as an additional drive.
  11. NickGR
    NickGR UDOOer
    Jun 23, 2020
    105
    Installed a new WD Blue SN550 NVME 1TB (WDS100T2B0C) and it works very nicely with Windows 10.
  12. hindumagic
    hindumagic New Member
    Mar 3, 2021
    Plugged in a WD-black 1TB NVMe drive and seems to be working well. BIOS sees it just fine. Installed void linux, UEFI style.
    lspci identifies it as: Sandisk Corp WD Black 2019/PC SN750
  13. Jason Gordon
    Jason Gordon New Member
    May 20, 2021
    Where do I find out how to do what you did? I have the same exact drive as the guy who started this whole thread and so it's in the NVMe slot. I have the Bolt V8. Thanks for any help you can give me!
  14. willipl1
    willipl1 New Member
    Mar 8, 2026
    Did you ever get this working? If I install varios different NVMe chips , the system hangs on startup. Works fine without using NVMe.
