what is the real reason we can't use eGPU with Type-C
Discussion in 'UDOO BOLT' started by linkhuntertwo, Jan 11, 2021.
  1. linkhuntertwo
    linkhuntertwo UDOOer
    Oct 29, 2019
    license issues?
  2. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    This is one of the misunderstandings in the messy USB (or USB-ish) world.
    There is the physical connector (looked the same) USB Type-C "Connector".
    Then there are different interface specifications running on top of that physical connector.
    Examples are ThunderBolt 3, USB 3, etc.
    Note that ThunderBolt 3 (TB3) genrally is a superset of USB3 in some aspect, such as it supports PCIe and can run at 40 Gbps.
    USB 3.1 type 1 is 5 Gbps and type 2 is 10 Gbps.
    Now the eGPU's (externa GPU) interface is PCIe.
    There is no PCIe support in USB 3. That is the end of the story. You need TB3 for your eGPU attachment. LP Alpha/Delta does not have TB3.
