Udoo Bolt V8 no sound over HDMI
Discussion in 'UDOO BOLT' started by palita, Dec 25, 2019.
  1. palita
    palita UDOOer
    Jun 12, 2018
    Hi, anyone experiencing problem with sound over HDMI?
    At first I tought that there was a driver issue in windows 10, couln't get any audio out from windows 10 to the TV. The audio control says there is a problem with the driver and the volume and audio icons are grey.
    So i switched to linux (ubuntu) to check and there too I couldn't get audio out to the TV. So it appears as if it is hardware realted.
    Analog audio works and I could not try the integrate speakers neither the spdif out but they appear in normal color so i assume they work fine.
  2. PhMenard
    PhMenard UDOOer
    Dec 11, 2019
    Hi Palita,
    no problem here. V8 running Fedora 31, sound over HDMI works great.
    Hope this helps, Philippe.
    evaloverde likes this.
  3. Leonardo
    Leonardo UDOOer
    Jan 5, 2020
    Same here. I used bluetooth to get the sound out.
  4. Hey Blud
    Hey Blud UDOOer
    May 5, 2020
    Hi Palita,
    For Windows, you have to download AMD Radeon Software Adrenalin 2020 Edition. The HDMI sound is controlled by the display drivers. It may not be the only way but I not tech savvy enough to go into it.
  5. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I have the same problem with Ubuntu MATE 18.04 and 20.04. So far, I have not figured out how to fix this. I just do not get sound through the HDMI port.
    8-Dale
  6. waltervl
    I have no issues in getting sound out with HDMI (Ubuntu 20.04 LTS). You have to set the speaker out.
    I had 1 issue. I installed VLC and set the volume low (or off, I don't remember). That also set the global volume that could not be restored.
    I had to set VLC to normal volume levels again.
  7. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I am glad that you have sound. I have tried every solution I have found on the net but I still do not have sound over HDMI. I am running Ubuntu MATE' 18.04 on a UDOO Bolt V8 with 32Gb RAM and 1Tb SSD.
    8-Dale
  8. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    Update: I DO get sound when I play Big Buck Bunny, but I do not get sound when trying to watch YouTube videos. I can not find a setting that will affect this.
    8-Dale
  9. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I get sound out HDMI when I play local files, but not when streaming something off YouTube or elsewhere.
    8-Dale
  10. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Audio stream embedded in HDMI signals can be digital stereo (PCM at various bit rate), Dolby Digital, etc.
    If your HDMI monitor can decode digital stereo (which is the most basic one) and sound well, but not on other streaming sources,
    you'll have to trace the audio stream format (especially advanced Dolby format) and find out where such format is decoded.
    Hint: a plain, inexpensive computer monitor cannot decode Dolby Digital oe even Digital PCM steoreo a 192 kbps, while a higher end monitor or HDTV (broadcast ATSC's audio signal is Dolby AC-3) can.
  11. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Also, try play audio on local 3.5mm headphone port. This validate if audio stream can be decoded with proper audio plug-ins.
  12. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    My "monitor" is a 43" Toshiba HDTV, so it should be able to decode everything.
    8-Dale
  13. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Try few possible scenarios
    - play file locally thru 3.5mm headphone jack, not thru HDMI audio stream
    - play file which only in embeds Dolby Digital audio format, not Digital Stereo format
    (or stream from Internet such as YT, but select specific audio format)
    - try several types of HDMI display devices (HDTV, computer monitor, etc.)
    - try a different HDMI cable (1.4 or 2.0)
    Use these to deduce the missing element...
  14. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I will try getting audio from the 3.5mm headphone jack if it does not need a special connector
    How do I select specific audio formats with YouTube?
    I only have one HDMI display device - my Toshiba 43" HDTV
    All my HDMI cables are the same - I got them in a bundle.
    8-Dale
  15. waltervl
    For Youtube video's try another browser (eg Chromium).
  16. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I already use Chrome as my default browser - Chromium for Linux.
  17. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I tried the analog audio out today but did not get any sound at all.
    Neither Chrome nor Firefox yield any sound.
    Ubuntu MATE and Linux Mint MATE do not get sound through HDMI.
    8-Dale
  18. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    On my UDOO Bolt V8 with 32Gb RAM and 1Tb SSD:
    1) I have tried two different Linux distributions, Ubuntu MATE and Linux Mint MATE, and do not get sound through HDMI.
    2) Neither Chrome nor Firefox will produce sound.
    3) I do not get sound through the headphone jack.
    8-Dale
  19. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
  20. hybotics
    hybotics UDOOer
    May 13, 2020
    24
    I have not installed the AMDGPU driver.
    8-Dale
