UDOO BOLT Basic Case
Discussion in 'UDOO BOLT' started by RedMod, Jan 30, 2021.
  1. RedMod
    RedMod UDOOer
    Jan 21, 2020
    Hello to all.
    I have finally finished my basic case. modeled in Blender and printed out on Prusa i3 MK3S.
    It is a minimalist design, lightweight, easy to assemble and sturdy.
    It does not need support for printing. I have used metric 3mm screws to put it together.
    For the honeycomb mesh, I have used a modifier in PrusaSlicer.
    The walls are 2mm thick. It is shared under GPL license, so feel free to adjust as you please :)
    Shared on thingiverse and myminifactory :
    https://www.thingiverse.com/thing:4714659
    https://www.myminifactory.com/object/3d-print-udoo-bolt-basic-case-149174
    I can share the blender files as well, but since you can import the stl files there is probably no need.
    evaloverde likes this.
  2. nophead
    nophead UDOOer
    Aug 18, 2015
    87
    14
    Nice.
  3. evaloverde
    Apr 29, 2019
    236
    60
    Very nice! Do you need a particular kind of material to deal with the heat?
  4. RedMod
    RedMod UDOOer
    Jan 21, 2020
    Thank you nophead, i appreciiate it :)
  5. RedMod
    RedMod UDOOer
    Jan 21, 2020
    Hello, no special material, i am using standard PETG to print as it is heat and deformation resistant. I suppose PLA could be used as well but it is more brittle.
  6. RedMod
    RedMod UDOOer
    Jan 21, 2020
    I am working on a new version with 3mm walls and additional honeycomb modifier object. The modifier will be user to cut ventilation holes out of the walls.
  7. evaloverde
    Apr 29, 2019
    236
    60
    Hey RedMod, if you wish you can link your 2.0 version here!
  8. RedMod
    RedMod UDOOer
    Jan 21, 2020
