USBC DP alternate mode output not working
Discussion in 'UDOO BOLT' started by marcoAlfamation, Apr 4, 2022.
Tags:
  1. marcoAlfamation
    marcoAlfamation UDOOer
    Feb 15, 2022
    Hello,
    I just received my UDOO bolt V3 board, and I'm starting to test it.
    So far pretty much everything is OK, except the one and only feature I need the board for :( , the USBC alternate mode Displayport output.
    I use this adapter to plug it to the monitor:
    https://www.reichelt.com/de/en/usb-3-1-cable-c-male-to-dp-male-1-2-m-goobay-79295-p214745.html?r=1
    But it acts like nothing is connected at all.
    The OS installed is Ubuntu 21.10, and I plat to replace it with 22.04 once is out.
    Xrandr just tell me :
    DP-1 Disconnected (...
    DP-2 Disconnected (...
    Do you have any clue about what can be wrong?
    Thanks,
    Marco
  2. gl0p
    gl0p UDOOer
    Mar 26, 2022
    Hey, I know Ubuntu 21 and 22 are "expeirmental" in a way, meaning their not as fully tested as say 20. Some features may not work. I would try other operating systems, like Ubuntu 20 or windows 10 and see if your still having the same issue.
    In Ubuntu you can use "dmesg | grep hdmi" to see if its being initialized at all. If there are any errors you could google them and see what people say.
  3. ccs_hello
    ccs_hello UDOOer
    Apr 15, 2017
    536
    194
    Always install the most current AMD CPU/GPU driver (Ryzen V1605B)!
    re: DP-1 Disconnected (...
    Is it possibe it was due to HDCP negotiation error?
    I know the following config will always work:
    1. Find a universal USB-C "USB 3.x hub + HDMI output + SD Crd reader" all-in-one unit.
    Plug that unit's USB-C male side into UDOO Bolt's USB-C female port. (You can even power the BOLT thru that unit.)
    2. Connect a HDMI-to-HDMI (male-male) cable from that all-in-one unit to a known-working HDMI monitor.
  4. marcoAlfamation
    Feb 15, 2022
    It's connected to a normal monitor and i coud not find anything HDCP related in the bios settings.
    Unfortunately i need DP alternate mode to work properly, even if this setup works it would make no difference.
    I have an update about my previous post:
    It's the hotplug that is not working, if I start with the port connected the display stays on.
    If you try to plug and unplug the USB C with your adapter, do you get the video back?
    I tested the same cable with the same monitor and the same HDD (with the software) with a laptop with a thunderbolt port, works flawlessly.
    I would also say that the OS or the software has little to do with this, since i can reproduce the problem even when navigating the bios.
    I guess there is something with the firmware handling the PD protocol.
    My setup equal to the most basic USB-DP test setup, i think this feature has been tested and proved working...
    Thanks for your reply!
  5. bhojak
    bhojak UDOOer
    Apr 20, 2022
    Bridal Lehenga Supplier In India
    [​IMG]
    One of them is the Bridal lehenga, which is not a common lehenga however, it is the most special lehenga worn by a girl not even in India but across the globe. It is a dream lehenga, which every bride wants for her wedding day to make it a delightful and memorable day. Therefore, we are the preeminent bridal lehenga supplier in India. Now, no need to travel from one wholesaler to another wholesaler in search of a trustworthy bridal lehenga wholesaler, just tell us your necessities and we will create your bridal lehenga as per requirement at an affordable price at your doorstep.
