Arduino keep working
Discussion in 'UDOO BOLT' started by Fatih, May 11, 2022.
  1. Fatih
    Fatih UDOOer
    May 11, 2022
    Hello, When we turn off the system, the arduino and fan of Udoo Bolta continue to work. I'm curious about your suggestions for shutting down the Arduino. Thanks.
  2. NickGR
    NickGR UDOOer
    Jun 23, 2020
    105
    The attached Arduino is working correctly, it should remain operational as a seperate board no matter the state of the rest of the Bolt.
    I even trying to use the Wake# (EC Pin 12) to wake up the Bolt from the Arduino with sensor events, that would not be possible if the Arduino was being shutdown as well.
    I am not sure why your fan is working after you shutdown the main board though.
  3. NickGR
    NickGR UDOOer
    Jun 23, 2020
    105
    Correction, Wake# is Pin6
