Red circles on Bolt Gear order page?
Discussion in 'General Discussion' started by Charlie Kapopoulos, Apr 14, 2022.
  1. Charlie Kapopoulos
    Charlie Kapopoulos UDOOer
    Apr 14, 2022
    What do they mean? Does a red circle for ethernet mean the board doesn't not have integrated ethernet? The pictures of the case suggest it does so I am confused on the red circles.
  2. Orvalsampson
    Orvalsampson New Member
    Dec 1, 2022
    Bolt Circle Diameter (BCD) is the diameter of the circle that goes through the center of all of the bolts on your chainring. To unlatch the belt, press the red button on the buckle.
  3. Shauna Brown
    Shauna Brown New Member
    May 1, 2024
    I have a suggestion for your problem. A red circle for Ethernet usually means there’s no active connection or it’s disabled. It doesn’t mean the board lacks Ethernet. If you see a red light, try running a Windows troubleshooter or restart your computer to fix the issue.
    I hope my suggestion will be helpful for you.
