Hello Everyone, I need some advice because I'm working on a project that combines UDOO X86 with Internet of Things apps. My objective is to use the UDOO board to build up a smart home system that links multiple sensors (motion, temperature, and humidity) to a central hub. I intend to utilise MQTT to facilitate communication between devices, but I'm having trouble getting the sensors and the board to interact correctly. I have the following specific queries: Has anyone used MQTT to effectively integrate several IoT devices with the UDOO X86? If yes, any advice on how to set up the network effectively? Which power-management techniques work best when UDOO X86 is being used for continuous monitoring? Would you suggest any particular libraries or tools, especially for Python or Node.js users, for connecting UDOO with Internet of Things devices? Thank you very much for any guidance, resources, or examples that you could provide! Any assistance would be helpful as I'm still getting to know the platform. Thanks in advance.
To get those sensors talking, I'd suggest running Mosquitto as your local broker right on the board. For the software side, Node-RED is a lifesaver it lets you drag-and-drop your MQTT logic and visualize your sensor data without getting buried in hundreds of lines of code.
