Migrating device tree for Udooneo from 4.1 to 6.6 : Display (LVDS)
Discussion in 'UDOO NEO' started by CartonDu, Oct 10, 2025.
  1. CartonDu
    CartonDu UDOOer
    Apr 23, 2018
    I’m migrating a device from Yocto thud to scarthgap and moving from a custom 4.1 kernel (fmntf/linux_kernel 4.1.15_2.x-udoo) to linux-fslc-imx 6.6. Hardware is Udooneo Extended (iMX6SoloX) with the stock 7" LVDS panel (UMSH-8596MD-20T w/ DS90CF364 + ST1332 touch).
    Goal: run X11 with etnaviv (hardware accelerate) because the newer imx-viv-gpu doesn’t support X11 for our Electron apps.
    What works:
    • Screen backlight and splash are visible during early boot.
    • Touch works.
    Problem:
    • At a certain point during boot the LVDS image gets heavy tearing/grey lines. X starts but the same tearing appears. Looks like a mode/driver handover problem.
    What I’m attaching (below):
    • current device-tree fragment (imx6sx-udoo-neo-lvds7.dtsi).
    • some useful logs and outputs I captured (dmesg, Xorg log, /dev/dri listing).
    Current device-tree fragment (imx6sx-udoo-neo-lvds7.dtsi) which is mostly the same as the one from kernel 4.1:
       reg_lcd_pwr: regulator-lcdpwr {
           compatible = "regulator-fixed";
           regulator-name = "LCD POWER";
           gpio = <&gpio4 27 GPIO_ACTIVE_LOW>;
           enable-active-high;
           regulator-boot-on;
           regulator-always-on;
           status = "okay";
       backlight_regulator: regulator-backlight {
           regulator-name = "LCD BACKLIGHT BL_ON";
           gpio = <&gpio6 3 GPIO_ACTIVE_LOW>;
           enable-active-high;
           regulator-boot-on;
    &lcdif2 {
       display = <&display1>;
       disp-dev = "ldb";
       status = "okay";
       display1: display@1 {
           bits-per-pixel = <16>;
           bus-width = <18>;
    &ldb {
       pinctrl-names = "default";
       pinctrl-0 = <&pinctrl_ldb_0>;
       lcd-supply = <&reg_lcd_pwr
                       &backlight_regulator>;
       status = "okay";
       lvds-channel@0 {
           fsl,data-mapping = "spwg";
           fsl,data-width = <18>;
           crtc = "lcdif2";
           status = "okay";
           display-timings {
               native-mode = <&timing1>;
               timing1: LDB-WVGA {
                   clock-frequency = <33660000>;
                   hactive = <800>;
                   vactive = <480>;
                   hback-porch = <56>;
                   hfront-porch = <50>;
                   vback-porch = <23>;
                   vfront-porch = <20>;
                   hsync-len = <150>;
                   vsync-len = <2>;
    &i2c1 {
       touchscreen: st1232@55 {
           compatible = "sitronix,st1232";
           reg = <0x55>;
           interrupt-parent = <&gpio6>;
           interrupts = <4 IRQ_TYPE_LEVEL_LOW>;
           pinctrl-0 = <&pinctrl_st1232>;
           gpios = <&gpio6 5 GPIO_ACTIVE_LOW>;
    &dcic2 {
       dcic_id = <1>;
       dcic_mux = "dcic-lvds";
       status = "okay";
    &lcdif1 {    /* Disable HDMI */
       status = "disabled";
    &i2c3 {        /* Disable HDMI */
    Here's some logs and outputs:
    user@host:~# dmesg | grep -E "etnaviv|drm|mxsfb"
    [    1.236707] etnaviv etnaviv: bound 1800000.gpu (ops 0xc0d7c0b8)
    [    1.244047] etnaviv-gpu 1800000.gpu: model: GC400, revision: 4645
    [    1.250843] etnaviv-gpu 1800000.gpu: Need to move linear window on MC1.0, disabling TS
    [    1.259865] [drm] Initialized etnaviv 1.4.0 20151214 for etnaviv on minor 0
    [    1.267241] Error: Driver 'mxsfb' is already registered, aborting...
    [    2.141557] mxsfb 2224000.lcdif: supply lcd not found, using dummy regulator
    [    2.237241] mxsfb 2224000.lcdif: registered mxc display driver ldb
    [    2.342101] mxsfb 2224000.lcdif: initialized
    user@host:~# ls /dev/dri/
    by-path  card0    renderD128
    user@host:~# ls /usr/lib/xorg/modules/drivers/modesetting_drv.so
    user@host:~# grep -E "(EE|WW|etnaviv|modesetting|DRM)" /var/log/Xorg.0.log
    [   110.902] Current Operating System: Linux pad2 6.6.101-lf-6.6.y-lf-6.6.y-g36cee4c51e9a #1 PREEMPT Fri Aug  8 14:52:48 UTC 2025 armv7l
       (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    [   110.944] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
    [   110.944] (WW) The directory "/usr/share/fonts/X11/TTF" does not exist.
    [   110.944] (WW) The directory "/usr/share/fonts/X11/OTF" does not exist.
    [   110.944] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
    [   110.944] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
    [   110.945] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
    [   110.966] (II) Platform probe for /sys/devices/platform/etnaviv/drm/card0
    [   111.079]     falling back to /sys/devices/platform/etnaviv/drm/card0
    [   111.416] (WW) Falling back to old probe method for fbdev
    [   111.707] (II) Initializing extension MIT-SCREEN-SAVER
    [   114.495] (II) XINPUT: Adding extended input device "st1232-touchscreen" (type: TOUCHSCREEN, id 6)
    user@host:~# glxinfo | grep -E "OpenGL renderer|OpenGL vendor"
    Error: unable to open display
    user@host:~# export DISPLAY=:0
    Error: unable to open display :0
    What I expect:
    • a stable LVDS framebuffer handed to KMS/etnaviv and a working X11 modesetting driver with hw accel (no tearing).
    What I’ve already tried:
    • Using etnaviv (driver loads; /dev/dri/card0 exists).
    • Confirmed modesetting driver is present.
    • Left LVDS node mostly identical to old 4.1 .dtsi.
    Questions / hints I think are relevant (please point out if I’m wrong):
    1. Is the tearing likely caused by a DT timing mismatch or by a double-driver handover (mxsfb vs. etnaviv/modesetting)? I see Error: Driver 'mxsfb' is already registered, aborting....
    2. Do I need to enable/disable specific kernel CONFIGs (fbdev vs drm/KMS) or build etnaviv as builtin vs module for a clean handover?
    3. Are there DT properties I’m missing for the LDB -> lcdif2 CRTC mapping (crtc name, fsl,data-mapping, pixelclock) that would cause visible tearing?
    4. Anything obvious in the dts that will break atomic modeset / KMS?
    What I can provide on request:
    • uname -a, kernel .config, full dmesg, lsmod, cat /proc/fb, cat /sys/class/drm/*/status, and the full Xorg.0.log.
    Thanks for any pointers. I’m new to modern KMS/DT handover so please tell me bluntly if I misunderstood something.
    Hope someone is still active here :)
  2. CartonDu
    CartonDu UDOOer
    Apr 23, 2018
    I had to move away from meta-freescale and Freescale/NXP kernels. I'm using now linux-stable_6.12.bb from layer meta-linux-mainline (scarthgap) with following DTSI:
        reg_lcd_pwr: lcd_pwr {
            gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>;
            enable-active-high;
            regulator-boot-on;
        backlight_lvds: backlight {
            compatible = "gpio-backlight";
            gpios = <&gpio6 3 GPIO_ACTIVE_HIGH>;
            default-on;
        panel_lvds: panel-lvds {
            compatible = "umsh,8596md-20t", "panel-lvds";
            width-mm = <152>;
            height-mm = <91>;
            data-mapping = "jeida-18";
            power-supply = <&reg_lcd_pwr>;
            backlight = <&backlight_lvds>;
            status = "okay";
            panel-timing {
                clock-frequency = <33600000>;
                hactive = <800>;
                vactive = <480>;
                hback-porch = <56>;
                vback-porch = <23>;
                hsync-len = <150>;
                vsync-len = <2>;
                hsync-active = <0>;
                vsync-active = <0>;
                de-active = <1>;
                pixelclk-active = <0>;
            port {
                panel_in: endpoint {
                    remote-endpoint = <&lvds_bridge_out>;
    &gpu { /* Vivante GC400T */
        status = "okay";
    &lcdif1 {
        status = "okay";
        port {
            lcdif_out: endpoint {
                remote-endpoint = <&lvds_bridge_in>;
    &clks {
        assigned-clocks = <&clks IMX6SX_CLK_PLL5_VIDEO>,
                    <&clks IMX6SX_CLK_LDB_DI0_SEL>,
                    <&clks IMX6SX_CLK_LCDIF1_PRED>,
                    <&clks IMX6SX_CLK_LCDIF1_PODF>;
        assigned-clock-parents = <0>,
                    <&clks IMX6SX_CLK_PLL5_VIDEO_DIV>,
                    <0>,
                    <0>;
        assigned-clock-rates = <940800000>,
                    <0>,
                    <33600000>,
                    <33600000>;
    &gpr {
        status = "okay";
        lvds_bridge: bridge@18 {
            status = "okay";
            clocks = <&clks IMX6SX_CLK_LDB_DI0_SEL>;
            clock-names = "ldb";
            ports {
                #address-cells = <1>;
                #size-cells = <0>;
                port@0 {
                    reg = <0>;
                    lvds_bridge_in: endpoint {
                        remote-endpoint = <&lcdif_out>;
                port@1 {
                    reg = <1>;
                    lvds_bridge_out: endpoint {
                        remote-endpoint = <&panel_in>;
    &i2c1 { /* ST1332 or ST1633 Touch IC */
            reg = <0x55>;
    &lcdif2 { /* Disable HDMI */
    &i2c3 { /* Disable hdmi-transmitter */
    and following patch:
    diff --git a/arch/arm/boot/dts/nxp/imx/imx6sx-udoo-neo.dtsi b/arch/arm/boot/dts/nxp/imx/imx6sx-udoo-neo.dtsi
    index bbf792ac4896..c133299f48fc 100644
    --- a/arch/arm/boot/dts/nxp/imx/imx6sx-udoo-neo.dtsi
    +++ b/arch/arm/boot/dts/nxp/imx/imx6sx-udoo-neo.dtsi
    @@ -202,7 +202,7 @@ hdmi-transmitter@70 {
             ports {
                 port {
                     hdmi: endpoint {
    -                    remote-endpoint = <&lcdc>;
    @@ -216,18 +216,6 @@ &i2c4 { /* Onboard Motion sensors */
    -&lcdif1 {
    -    pinctrl-names = "default";
    -    pinctrl-0 = <&pinctrl_lcd>;
    -    status = "okay";
    -    port {
    -        lcdc: endpoint {
    -            remote-endpoint = <&hdmi>;
     &iomuxc {
         pinctrl_bt_reg: btreggrp {
             fsl,pins =
    2.44.4
    Thanks to Bootlin and especially Louis C. who managed to find this solution.
  3. James Herrera
    James Herrera New Member
    Jan 9, 2026
    Could you share your recipe for building this?
  4. jerry marlowe
    jerry marlowe New Member
    Feb 9, 2026
  5. CartonDu
    CartonDu UDOOer
    Apr 23, 2018
    Sorry guys. I didn't expected any answer actually. Need to enable my notifications.
    I will share on Monday the recipe.
  6. CartonDu
    CartonDu UDOOer
    Apr 23, 2018
    I've made a small tutorial with the help of Claude which I can share here. It's Markdown so feel free to paste in an another editor to read it in good conditions.
    # LVDS 7" display support on UDOO NEO (mainline Linux 6.12)
    This enables an 800x480 LVDS panel (e.g. UMSH-8596MD-20T) on the UDOO NEO
    Extended using **mainline Linux 6.12.x** (tested on 6.12.77).
    The upstream `imx6sx-udoo-neo.dtsi` hardwires `lcdif1` to the HDMI transmitter.
    We need to remove that binding, then add our own LVDS device-tree overlay.
    ## 1. Kernel patch: free lcdif1 from HDMI
    Apply this patch to the kernel source. It removes the `lcdif1 <-> hdmi`
    endpoint link in the upstream `imx6sx-udoo-neo.dtsi`, freeing LCDIF1 for
    the LVDS bridge.
    ```diff
             ports {
                 port {
                     hdmi: endpoint {
    -&lcdif1 {
    -    status = "okay";
    -    port {
    -        lcdc: endpoint {
     &iomuxc {
             fsl,pins =
    ## 2. Device tree include: `imx6sx-udoo-neo-lvds7.dtsi`
    Add this file to `arch/arm/boot/dts/nxp/imx/` and `#include` it from your
    board `.dts`.
    It sets up the full display pipeline:
    **LCDIF1 -> LDB (LVDS bridge) -> panel** with a GPIO-controlled backlight
    and an optional Sitronix ST1232 touchscreen on I2C1.
    ```dts
            enable-active-high;
            regulator-boot-on;
            default-on;
            width-mm = <152>;
            height-mm = <91>;
            status = "okay";
            panel-timing {
                hactive = <800>;
                vactive = <480>;
                hback-porch = <56>;
                vback-porch = <23>;
                hsync-len = <150>;
                vsync-len = <2>;
                hsync-active = <0>;
                vsync-active = <0>;
                de-active = <1>;
            port {
        status = "okay";
    &lcdif1 {
        status = "okay";
                    <0>,
                    <0>;
                    <0>,
                    <33600000>,
                    <33600000>;
        port {
    &gpr {
        status = "okay";
            status = "okay";
            ports {
                #size-cells = <0>;
                port@0 {
                    reg = <0>;
                port@1 {
                    reg = <1>;
    &i2c1 { /* ST1232 or ST1633 Touch IC */
            reg = <0x55>;
    ## 3. Pinctrl: required pad configuration
    The LVDS GPIOs (backlight, panel power, touchscreen) need their pads
    configured. Add this to your `&iomuxc` node:
    ```dts
    &iomuxc {
        pinctrl_ldb_0: ldbctrlgrp-0 {
            fsl,pins = <
                MX6SX_PAD_SD1_DATA1__GPIO6_IO_3     0x80000000  // BL_ON
                MX6SX_PAD_QSPI1B_DATA3__GPIO4_IO_27 0x80000000  // PANEL_ON
        pinctrl_st1232: st1232grp-0 {
            fsl,pins = <
                MX6SX_PAD_SD1_DATA2__GPIO6_IO_4  0x80000000  // TOUCH_INT
                MX6SX_PAD_SD1_DATA3__GPIO6_IO_5  0x80000000  // TOUCH_RST
    ## 4. Kernel config options (relevant subset)
    Make sure these are enabled for the display pipeline:
    CONFIG_DRM=y
    CONFIG_DRM_FBDEV_EMULATION=y
    CONFIG_DRM_PANEL_LVDS=m
    CONFIG_DRM_PANEL_SIMPLE=m
    CONFIG_DRM_FSL_LDB=m
    CONFIG_DRM_LVDS_CODEC=m
    CONFIG_DRM_ETNAVIV=m
    CONFIG_DRM_MXSFB=m
    CONFIG_DRM_IMX_LCDIF=m
    CONFIG_FB_DEVICE=y
    CONFIG_LCD_CLASS_DEVICE=y
    CONFIG_BACKLIGHT_CLASS_DEVICE=m
    CONFIG_BACKLIGHT_GPIO=m
    CONFIG_INPUT_TOUCHSCREEN=y
    CONFIG_TOUCHSCREEN_ST1232=y
    ## 5. Yocto recipe: `linux-udoo_6.12.bb`
    If you build with Yocto/OE, here is a cleaned recipe. It requires the
    [meta-linux-mainline](https://github.com/pidge/meta-linux-mainline) layer
    for `linux-stable.inc`.
    Place the `.dtsi`, `.dts`, `.patch` and `defconfig` files under
    `recipes-kernel/linux/linux-udoo/`.
    ```bitbake
    require recipes-kernel/linux/linux-stable.inc
    FILESEXTRAPATHS:prepend := "${THISDIR}/${BPN}:"
    COMPATIBLE_MACHINE = "(udooneo)"
    # To upgrade: copy LINUX_VPATCH + SRCREV from meta-linux-mainline/linux-stable_6.12.bb
    LINUX_VMAJOR = "6"
    LINUX_VMINOR = "12"
    LINUX_VPATCH = "77"
    SRCREV = "6f232446a62980e51f537db1c655e686d869b9ed"
    SRC_URI:append = " \
        file://imx6sx-udoo-neo-lvds7.dtsi \
        file://imx6sx-udoo-neo-lvds7.dts \
        file://defconfig \
        file://0001-Remove-lcdif1-and-hdmi-transmitter-endpoint.patch \
    KBUILD_DEFCONFIG:udooneo = ""
    KERNEL_LOCALVERSION:udooneo = "-udooneo-lvds"
    # Install dtsi/dts into kernel tree after patches are applied
    do_patch:append() {
        install -m 0644 ${WORKDIR}/imx6sx-udoo-neo-lvds7.dtsi \
            ${S}/arch/arm/boot/dts/nxp/imx/imx6sx-udoo-neo-lvds7.dtsi
        install -m 0644 ${WORKDIR}/imx6sx-udoo-neo-lvds7.dts \
    do_recompile_dtb() {
        cd ${B}
        oe_runmake nxp/imx/imx6sx-udoo-neo-lvds7.dtb
    addtask recompile_dtb before do_compile after do_configure
    The board `.dts` (`imx6sx-udoo-neo-lvds7.dts`) would look like:
    ```dts
    // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
    /dts-v1/;
    #include "imx6sx-udoo-neo.dtsi"
    #include "imx6sx-udoo-neo-lvds7.dtsi"
        model = "UDOO NEO Extended with LVDS";
        compatible = "udoo,neoextended", "fsl,imx6sx";
        memory@80000000 {
            device_type = "memory";
            reg = <0x80000000 0x40000000>;
    &uart3 { /* Bluetooth */
        status = "okay";
    Don't forget to add the pinctrl definitions from section 3 - either inline
    in the `.dts` or in a separate `.dtsi`.
    Tested on UDOO NEO Extended with a 7" LVDS panel (UMSH-8596MD-20T / URT UMSH-8596MD-20T compatible) on mainline Linux 6.12.77.
  7. CartonDu
    CartonDu UDOOer
    Apr 23, 2018
    Also, if you are using U-Boot, be aware that commit 99a94c368c9056acf8107ae4163efbb1cbe34d42 introduced a bug. You may see about half of your UDOONEO boards panic during boot.
    As a result, with U-Boot you are limited to version 2022.07 or earlier.
    If you need a newer version, you can apply this patch which reverts part of the faulty commit:
    From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001
    Date: Tue, 25 Mar 2026 10:00:00 +0000
    Subject: [PATCH] board: udoo neo: fix PMIC device name and restore voltage
     programming
    Upstream-Status: Inappropriate
    Commit 99a94c368c9 ("udoo_neo: Move to DM for REGULATOR/PMIC/I2C
    drivers") migrated from the legacy PMIC framework to DM but introduced
    two bugs:
    1. pmic_get() is called with "pfuze3000@8" but the DT node is named
       "pmic@8", so the lookup always fails with -ENODEV and the function
       silently returns without configuring anything.
    2. The voltage programming (VDD_ARM, VDD_SOC, DDR, standby voltages,
       ramp rates, VGEN2) was removed during the migration. Without these
       settings the board runs on PFUZE3000 power-on defaults, causing
       memory corruption and instability.
    Fix the device name and restore the full voltage configuration using the
    DM pmic_reg_read/pmic_reg_write API, matching the values from the
    original POWER_LEGACY implementation.
    Signed-off-by: Carton <myemail@notdisclosed.com>
     board/udoo/neo/neo.c | 53 +++++++++++++++++++++++++++++++++++++++++++-
     1 file changed, 52 insertions(+), 1 deletion(-)
    diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c
    index d99d93b44ae..4d2322ae04e 100644
    --- a/board/udoo/neo/neo.c
    +++ b/board/udoo/neo/neo.c
    @@ -78,9 +78,9 @@ int dram_init(void)
     int power_init_board(void)
         struct udevice *dev;
    -    int ret, dev_id, rev_id;
    +    int ret, dev_id, rev_id, reg;
    -    ret = pmic_get("pfuze3000@8", &dev);
    +    ret = pmic_get("pmic@8", &dev);
         if (ret == -ENODEV)
             return 0;
         if (ret != 0)
    @@ -90,8 +90,58 @@ int power_init_board(void)
         rev_id = pmic_reg_read(dev, PFUZE3000_REVID);
         printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id);
    +    /* disable Low Power Mode during standby mode */
         pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1);
    +    /* set all switchers to APS mode (auto power save) */
    +    pmic_reg_write(dev, PFUZE3000_SW1AMODE, 0xc);
    +    pmic_reg_write(dev, PFUZE3000_SW1BMODE, 0xc);
    +    pmic_reg_write(dev, PFUZE3000_SW2MODE, 0xc);
    +    pmic_reg_write(dev, PFUZE3000_SW3MODE, 0xc);
    +    /* set SW1A standby voltage 0.975V */
    +    reg = pmic_reg_read(dev, PFUZE3000_SW1ASTBY);
    +    reg &= ~0x3f;
    +    reg |= PFUZE3000_SW1AB_SETP(9750);
    +    pmic_reg_write(dev, PFUZE3000_SW1ASTBY, reg);
    +    /* set SW1B standby voltage 0.975V */
    +    reg = pmic_reg_read(dev, PFUZE3000_SW1BSTBY);
    +    reg &= ~0x3f;
    +    pmic_reg_write(dev, PFUZE3000_SW1BSTBY, reg);
    +    /* set SW1A/VDD_ARM_IN step ramp up time from 16us to 4us/25mV */
    +    pmic_clrsetbits(dev, PFUZE3000_SW1ACONF, 0xc0, 0x40);
    +    /* set SW1B/VDD_SOC_IN step ramp up time from 16us to 4us/25mV */
    +    pmic_clrsetbits(dev, PFUZE3000_SW1BCONF, 0xc0, 0x40);
    +    /* set VDD_ARM_IN to 1.350V */
    +    reg = pmic_reg_read(dev, PFUZE3000_SW1AVOLT);
    +    reg &= ~0x3f;
    +    reg |= PFUZE3000_SW1AB_SETP(13500);
    +    pmic_reg_write(dev, PFUZE3000_SW1AVOLT, reg);
    +    /* set VDD_SOC_IN to 1.350V */
    +    reg = pmic_reg_read(dev, PFUZE3000_SW1BVOLT);
    +    reg &= ~0x3f;
    +    pmic_reg_write(dev, PFUZE3000_SW1BVOLT, reg);
    +    /* set DDR_1_5V to 1.350V */
    +    reg = pmic_reg_read(dev, PFUZE3000_SW3VOLT);
    +    reg &= ~0x0f;
    +    reg |= PFUZE3000_SW3_SETP(13500);
    +    pmic_reg_write(dev, PFUZE3000_SW3VOLT, reg);
    +    /* set VGEN2_1V5 to 1.5V and enable */
    +    reg = pmic_reg_read(dev, PFUZE3000_VLDO2CTL);
    +    reg &= ~0x0f;
    +    reg |= PFUZE3000_VLDO_SETP(15000);
    +    reg |= 0x10;
    +    pmic_reg_write(dev, PFUZE3000_VLDO2CTL, reg);
         return 0;
    2.44.4
