I2S bit perfect digital audio output
Discussion in 'General Discussion' started by TBM, Mar 1, 2014.
  1. TBM
    TBM New Member
    Feb 26, 2014
    Hmmm. From highlights of new features listed on Rev C board: I2S/AC97/SSI...
    I think we are now on Rev D now?
    I do need to get bit perfect digital audio out on native 44.1KHz, 48KHz and multiples via I2S to an external DAC.
    I wonder if it is possible to configure UDOO to put out this via some GPIO pins?
    I can also solder if needed...
    SW and HW tips are MUCH appreciated!
    Cheers
    TBM
  2. TBM
    TBM New Member
    Feb 26, 2014
    One thing to note:
    We don't need a DAC master clock (sck) because I am using the DAC (ES9018 asynchronously with 100Mhz clock).
    PCM pins: bitclock, wordclock, data. Must have - most important I2S feature.
    DSD pins : bitclock and data(1 and 2). Nice to have feature...
    The raspberry pi can do this, so I do hope UDOO can as well... ;-)
    Cheers
  3. 5lifes
    5lifes New Member
    Mar 3, 2014
    Hello,
    I've also bought a board believing that I2S is available right away. Would like to use it with Volumio, but as I understand the implementation is missing because of a "driver" not being available from your side - not sure if it is right.
    In any event, please do your best to make this feature available!
    Thank you!
  4. ede_bruni
    ede_bruni New Member
    Mar 6, 2014
    I would support this request.
    Highly awaited funktion. :)
  5. fabulou$
    fabulou$ New Member
    Nov 5, 2013
    25
    +1..
  6. indianerjones
    indianerjones New Member
    Mar 10, 2014
    18
    I need I²S as well. Has anybody worked out how to configure the kernel yet?
    These pins need to be set in arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h:
    	// MX6Q_PAD_DISP0_DAT13__GPIO_5_7,							// pin 29
    	MX6Q_PAD_DISP0_DAT13__AUDMUX_AUD5_RXFS,
    	// MX6Q_PAD_DISP0_DAT14__GPIO_5_8,							// pin 30
    	MX6Q_PAD_DISP0_DAT14__AUDMUX_AUD5_RXC,
    	// MX6Q_PAD_DISP0_DAT16__GPIO_5_10,						// pin 32
    	MX6Q_PAD_DISP0_DAT16__AUDMUX_AUD5_TXC,
    	// MX6Q_PAD_DISP0_DAT17__GPIO_5_11,						// pin 33
    	MX6Q_PAD_DISP0_DAT17__AUDMUX_AUD5_TXD,
    	// MX6Q_PAD_DISP0_DAT18__GPIO_5_12,						// pin 34
    	// MX6Q_PAD_DISP0_DAT18__ECSPI2_SS0,
    	MX6Q_PAD_DISP0_DAT18__AUDMUX_AUD5_TXFS,
    	// MX6Q_PAD_DISP0_DAT19__GPIO_5_13,						// pin 35
    	MX6Q_PAD_DISP0_DAT19__AUDMUX_AUD5_RXD,
    Don't forget to remove them from mx6q_set_in_inputmode[] as well.
    Where do I go from here? Somehow I need the proper initialization in arch/arm/mach-mx6/board-mx6_seco_UDOO.c, but I don't know what exactly needs to done.
