Multiple USB Cameras
Discussion in 'General Discussion' started by jaeg, Jul 3, 2014.
  1. jaeg
    jaeg Member
    Oct 22, 2013
    62
    Sorry if this is in the wrong place.
    I'm trying to use stereo vision in OpenCV however I've hit a snag. I'm guessing that since the USB ports are on the same bus when I try to activate the second camera it gives:
    libv4l2: error turning on stream: No space left on device
    VIDIOC_STREAMON: No space left on device
    Similar situation happens when I open the Webcam Utility program twice each one set to a different camera.
    I'm unsure if there is any obscure Linux magic to fix this issue.
    Thanks!
  2. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    It's better to see which /dev/video number are assigned to each camera. This way you should be use both cameras...
    So, let's see. First connect one camera, then the other (system should be already on).
    Then type:
    dmesg | tail
    Paste output here
  3. jaeg
    jaeg Member
    Oct 22, 2013
    62
    One is dev/video3 and the other is dev/video4
  4. jaeg
    jaeg Member
    Oct 22, 2013
    62
    I can get one camera working at a time but not both.
    Finally got time to run dmesg here's the output:
    They typically load up as video3 and video4. So likewise in openCV I use 3 and 4 for the camera index numbers.
    I tried
    rmmod uvcvideo
    modprobe uvcvideo quirks=128
    But was met with:
    ERROR: module uvcvideo does not exist in /proc/modules
  5. jaeg
    jaeg Member
    Oct 22, 2013
    62
    After running lsusb I noticed that there are two buses. Is bus 1 J24?
    In other words the primary USB, WIFI, etc seems to be on bus 2 while lsusb shows that there is a bus 1. So I'm hoping bus 1 is the third USB port. If that's the case getting the adapter would fix the bandwidth issue of the webcam since (from what I've read) 1 camera can take about 60% of the bus bandwidth.
  6. jaeg
    jaeg Member
    Oct 22, 2013
    62
    For future knowledge: Third usb port is on Bus 2. No idea what bus 1 is used for.
  7. anders
    anders New Member
    Jul 14, 2014
    From my experience I think your intuition is correct: it's a bandwidth problem. Can you try using gvucview or something similar to reduce the resolution and/or framerate enough to get it working?
  8. jaeg
    jaeg Member
    Oct 22, 2013
    62
    I did. The webcams can not go into a small enough resolution in the MJPG format to work together. Some lower res cameras will be needed.
  9. jonathan
    jonathan New Member
    Jul 15, 2014
    Hello, how can i recognize a webcam trough my udoo quad, i cannot open it.
    Please help me
  10. jaeg
    jaeg Member
    Oct 22, 2013
    62
    It'll depend on the webcam. Not all work with Linux.
  11. mkopack
    Waht jaeg said. It has to be a UVC compatible camera. What I've found is that most Logitechs (since they got bought by microsoft) are NOT UVC.
    Basically if it says it requires Windows, you're screwed. If it says it works on Mac, you're good to go (Mac's also require UVC.)
