2 GPIO pins
Discussion in 'UDOO NEO' started by klakier2121, Dec 18, 2015.
  1. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Hello, I noticed that in external pins, there are two the same pins GPIO_124. They are: pin 41, pin 23. I checked and GPIO_124 is assigned to 41 pin, but what about pin 23?
    Thanks !
  2. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    If you review the dts you will see:
    pin 23 GPIO1_IO_24
    pin 41 GPIO4_IO_28
  3. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    pin 41 is GPIO_124
  4. Cyril BOSSELUT
    Cyril BOSSELUT New Member
    Oct 30, 2015
    23
    14
    if you follow the dts and the formula in the doc http://www.udoo.org/docs-neo/Hardware_&_Accessories/Gpio.html
    MX6SX_PAD_QSPI1B_DQS__GPIO4_IO_28 0x80000000 // {{external-gpio-41}}
    MX6SX_PAD_CSI_PIXCLK__GPIO1_IO_24 0x80000000 // {{external-gpio-23}}
    pin 41 -> GPIO(4)_IO_(28) => (4 - 1)*32 + 28 = 124
    pin 23 -> GPIO(1)_IO_(24) => (1 - 1)*32 + 24 = 24;
  5. klakier2121
    klakier2121 Member
    Dec 5, 2015
    48
    15
    Thanks! Close !
  6. jas-mx
    Dec 31, 2013
    407
    118
    Referring to these pins by a GPIO number (ie GIPO_124) doesn't make sense because the pins are multiplexed to a pad on the imx6. They should be reference by the pad ie CSI_PIXCLK or QSPI1B_DQS. That way the correct functions (ie GPIO/I2C/CAN ... etc) for the pad can be identified.
  7. Andrea Rovai
