5 volt tolerance
Discussion in 'UDOO NEO' started by Flavio Battimo, Nov 4, 2015.
  1. Flavio Battimo
    Flavio Battimo New Member
    Jun 8, 2015
    11
    Hello,
    Does M4 core is 5 volt tolerant on gpio pins?
    I want to connect a HC-SR04 ultrasonic distance sensor. It is 3.3 volt tolerant on trigger pin but i don't know if I can simply connect the output pin to the board without damaging the board itself.
    Thank you
  2. jasea
    jasea New Member
    Oct 30, 2015
  3. Flavio Battimo
    Jun 8, 2015
    11
    Hello John,
    this is the same trick I used on banana pi.
    My disappointment is that an Arduino Uno shield could have 5 volt signals. I thought that there were logic-level translators on each M4 pin to accomplish that.
  4. Andrea Rovai
    Dear Flavio,
    there's no logic-level translator as you say.
    In input you have to use a voltage divider. Take a look at this page.
  5. sirrab
    sirrab UDOOer
    Jul 26, 2014
    264
    32
    Link doesn't work.
  6. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
  7. Andrea Rovai
