Hi I'm trying to connect an Adafruit 8x8 bi-colour LED matrix via I2C to the Neo. The LED matrix works fine on a standard Arduino Uno R3 using the Adafruit example code. However, attaching this to the Neo's I2C 2 connectors stops the Neo from booting. If I try to connect SDA&SCL after the Neo has booted it doesn't stop the Neo running but IC2detect does not find it. Any suggestions anyone?
The Neo isn't "Arduino compatible", it just can be programmed through the Arduino IDE. You might need to adapt any library you are going to use in order to use it on the Neo. See "Porting Libraries" for more information.
And the I2C-2 that is attached to the Arduino SDA/SCL pins first have to be activated through the Device tree editor: http://www.udoo.org/docs-neo/Cookbook_Linux/Device_Tree_Editor.html I2C-2: SNAP-IN Bricks connector By default the snap-in connector is assigned to the A9 and it’s possible to control it by Linux driver. The I2C signal are also available on SDA - SCL pins and on pins 36/37. If you need to use this on the M4 Arduino core, you need to remove it from the A9 core, right-clicking on the corresponding pins and removing it. After a reboot it will be possible to connect an external I2C device to the SDA SCL pins and control it from the Arduino M4 core.
@waltervl. You are talking about the snap-in connector, but the default pins are 14 (SDA) & 15 (SCL), which are by default assigned to the M4. I connected a i2c sensor to the pins and it worked automatically.
Well, I dont understand the docs then Pin 14/15 are the same as SDA/SCL and connected to I2C-2. Only in the Device tree editor it is stated that I2C-2 is assigned to Linux and should be removed to have them available in Arduino.
Maurice It hangs when I power it up, so I don't manage to find out what is going on. Also, and sorry for the confusion, I'm not trying to access these from the Arduino core but from Linux. I only tested the LED matrix on an Arduino to check that it was still working! I actually want to use it via I2C under Linux.
It should work from the linux side although I never use the 'device tree editor' for alterations instead I manually update the dts files to my needs. For example I'm currently using I2C4 which are routed to J5 pins: GIPO_202/PWM_2/USB_HSIC_STROBE/I2C4_SDA GIPO_202/PWM_1/USB_HSIC_DATA/I2C4_SCL From memory I think you need to comment out the following lines in imx6sx-udoo-neo-externalpins.dtsi MX6SX_PAD_USB_H_STROBE__GPIO7_IO_11 0x80000000 // {{external-gpio-34}} MX6SX_PAD_USB_H_DATA__GPIO7_IO_10 0x80000000 // {{external-gpio-35}}
The i2c lines are pulled up high by resistors by default arduino is 5v but neo is 3.3v this is maybe your issue... Please check this before connecting any shield to neo Gesendet von meinem FP2 mit Tapatalk
