I've flashed TinyG2 on the SAM3X8E. But I am unable to contact it via ttymcx3. But I can flash the bin with bossac via the commandline via ttymcx3. But not access the 'console' of TinyG2. How does one go about configuring the Native USB port on the a SAM3X8E to be visible in Linux (UDOObuntu 1.1 for the quad) as a serial connection? (aka a ttyX). I've tested this bin file with a standard Arduino Due and it works correctly if I plug-in to the Native port, but not the programing port. So I am assuming the same issue is happening with the udoo. Thanks in advance.
Hi there ymilord, that port is used with otg bus. The connection however should be the same as if it is a native port. However this could be useful http://www.udoo.org/downloads/#tab5
