ACPI gpio mapping
Discussion in 'UDOO X86' started by yamikiri, Jun 11, 2021.
  1. yamikiri
    yamikiri New Member
    Apr 24, 2017
    I'm trying to enable an HID I2C device on Windows 10 using UDOO x86 II advanced plus.
    The bus I choose is I2C1 on Braswell and interrupt pin is 37 in CN14.
    By using "\\_SB.PCI0.I2C1" in ACPI table, I can successfully access I2C in windows.
    But Interrupt seems not working, I couldn't map pin 37 to ACPI GPIO name.
    I thought it was "\\_SB.GPO3" and the offset is 4A, but it isn't....
    Is there any reference to guide me correctly configure these GPIO?
    Below is ASL I use to bring up HID device:
    Device(MM)
            Name(_ADR, 0)
            Name(_HID, "MSFT1234")
            Name(_SUB, "MCMM7150")
            Name(_CID, "PNP0C50")
            Name(_HRV, 1)
            Name(_UID, 3)
            Method(_CRS, 0x0, NotSerialized)
                Name(RBUF, ResourceTemplate()
                    I2CSerialBus (0x40, ControllerInitiated, 400000, AddressingMode7Bit, "\\_SB.PCI0.I2C1", , , ,)
                    GpioInt (Level, ActiveLow, ExclusiveAndWake, PullNone, 0, "\\_SB.GPO3", 0, ResourceConsumer, ,) { 0x004A }
                Return(RBUF)
            Method(_DSM, 0x4, NotSerialized)
                // DSM UUID
                switch(ToBuffer(Arg0))
                    // ACPI DSM UUID for HIDI2C
                    case(ToUUID("3CDFF6F7-4267-4555-AD05-B30A3D8938DE"))
                        // DSM Function
                        switch(ToInteger(Arg2))
                            // Function 0: Query function, return based on revision
                            case(0)
                                // DSM Revision
                                switch(ToInteger(Arg1))
                                    // Revision 1: Function 1 supported
                                    case(1)
                                        Return(Buffer(One) { 0x03 })
                                    default
                                        Return(Buffer(One) { 0x00 })
                            // Function 1 : HID Function
                            case(1)
                                // HID Descriptor Address
                                Return(0x0001)
                            default
                                // Functions 2+: not supported
                                Return(0x0001)
                    default
                        // No other GUIDs supported
  2. yamikiri
    yamikiri New Member
    Apr 24, 2017
    Update:
    I've found a pin that I could match ACPI table with physical pin.
    It's GPIO_SUS3 which physical pin is 40@CN12
    The ACPI resource is 17@"\\_SB.GPO1".
    So I modified the asl code as follow and connect interrupt to 40@CN12, and the I2C HID device works.
    GpioIo(Shared, PullDefault, 0x0000, 0x0000, IoRestrictionInputOnly, "\\_SB.GPO1", 0, ResourceConsumer, ,) { 17 }
    GpioInt (Level, ActiveLow, ExclusiveAndWake, PullNone, 0, "\\_SB.GPO1", 0, ResourceConsumer, ,) { 17 }
