I wonder if/when anyone will come with the nice case for UDOO. As a very good example of aesthetics, I'd like to show this acrylic case for ODROID: Any ideas?
As a first step it would be nice to have some detailed geometric specs or a CAD-model for designing cases ... I wait for the UDOO Quad, so can I assume that until it is released, no specs will be published cause they might change ?
Yeah, I'm sure once the boards start shipping there will be some cases designed by folks appearing as well. I know I have a Laser cutter here at the office that I'd love to put to use! My hope is that there will be a case designed with sort of a modular section that can be opened/removed for access to the Arduino side - that's the problem with most of the Rasberry Pi cases - no access to the GPIO pins once it's in there, and/or no access to the CSI/DSI ports, etc. Hmm, I might have to start trying to sketch something up soon...
They are several example of Rpi cases here: http://elinux.org/Rpi_Cases It would be great to have 3D cases printable for the Udoo? Maybe the actual printable 2D & 3D Mechanical profile models of Udoo can help to create cases (http://www.kickstarter.com/projects/435 ... sts/576062)
The only issue I see with having the UDoo in a case is that it would restrict access to the Due side's headers... I'd suggest some sort of modular case- something where the non-Due side could be enclosed at all time (be even nicer if for the quad version it had room for an SSD or laptop HD) and then a removable cover for the Due side (or maybe a tall cover for that side with breakout holes for routing cables and such through.)
Not sure if there would be any interest. I am planning to make a Stainless case for my Udoo when it arrives. I manage a sheet metal shop and use pro engineer for 3D layout so I could make one from the model I downloaded from udoo. I don't typically use cases so if anyone interested could throw out some suggestions it would help me with making a nice modular. I could make cases out of aluminum, stainless, steel ...... I have punches to make knock outs mostly round and db-9, 25....
A case scheem would be sweet, one with knock out ports for customized use, or have cut outs so all the ports could Be open, like a sheet of plexiglass heat guned over the top of a printed model, maby a model slightly larger to prove air flow, when i get mine im makein a steam punk wood rout out with brass acents,
Hi, you can download UDOO 3D and 2D models from here http://www.udoo.org/downloads/#tab5 and here you can find out UDOO case file by Cussigh98 http://www.thingiverse.com/thing:152708
