Alimentazione di arduino
Discussion in 'Italiano' started by diglo, Apr 29, 2017.
  1. diglo
    diglo New Member
    Apr 29, 2017
    16
    Ciao a tutti,
    ho una UDOO X86 advanced in cui ho messo win10 su un SSD e mi chiedevo: com'è legata l'alimentazione del modulo arduino all'alimentazione della parte PC?
    Se metto windows in sospensione o lo spengo, anche arduino si spegne.
    In sostanza, arduino è acceso solo se il led di alimentazione è VERDE.
    Come si fa ad avere la parte X86 spenta ed arduino acceso?
    Devo alimentare arduino esternamente?
    diglo
    Ecco il mio UDOO:
  3. diglo
    diglo New Member
    Apr 29, 2017
    16
    Walter, I already tried to put win10 in sleep mode, the power LED goes from green to amber and the arduino powers down!
    Walter, ho già provato a mettere win10 in sleep, il led diventa arancione e l'arduino si spegne!
  4. waltervl
    You also have Hibernate (S5), what will that do?
    Sleep can also be configured as Modern Standby (S0)
    In this link I gave earlier there is also a command powercfg -a that shows all the states that are available.
    There is more information about this command here.
  5. diglo
    diglo New Member
    Apr 29, 2017
    16
    Ok Il' give it a try but it looks like it's not possibile to have the pentium completely OFF and the arduino ON at the same time...
    Ok farò qualche prova ma sembra quindi non possibile avere il pentium completamente OFF e arduino ON allo stesso tempo...
  6. diglo
    diglo New Member
    Apr 29, 2017
    16
    Yes, i know Arduino can act as a "power button presser", which can wake the main CPU from S3/S4/S5, namely: sleep/hibernation/OFF.
    The topic here is how to have arduino powered ON while the main CPU is in S3/S4/S5 states, which now looks impossible without an external power supply to the adruino (which I did not test yet).
  7. waltervl
    I understand you completely.
    But I think it is not clear how windows puts the CPU in one of these states. Perhaps there is an option in UEFI that can help?
    Eventually the documentation could help but Udoo team is not helping a lot here now. So we have to figure it out ourselves.
  8. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    Given that UDOO mentions the idea of starting the main CPU from the Arduino I'd be quite surprised if one needs a second power source to keep the Arduino running. It would void one of my ideas.
  9. diglo
    diglo New Member
    Apr 29, 2017
    16
    Putting the Braswell in S3 equals to put Win10 into Standby (with Win10).
    The command powercfg -a shows that S3=standby.
    Given that the cpu wakeup is done with a LOW 20ms pulse on IO9, I uploaded a sketch which just keeps IO9 HIGH al the time. The sequence of events is this:
    1. Win10 is running, arduino IO9 is high. Power LED is green
    2. I put win10 to standby
    3. Once windows goes to standby, the power to arduino is cut, IO9 goes LOW and windows wakes up again. The power LED turns amber for half a second, then green again.
    4. Windows is running again.
    You can't even put windows to sleep!
    Am I missing something?
    diglo
  10. waltervl
  11. diglo
    diglo New Member
    Apr 29, 2017
    16
    You are right @waltervl! I'll move there.
