Android and Arduino hello world tutorial: Null point exception error
Discussion in 'Android' started by Mariam, Mar 20, 2016.
  1. Mariam
    Mariam New Member
    Mar 20, 2016
    10
    I have tried the Hello world tutorial to blink the LED using UDOO QUAD , the link is below
    http://www.udoo.org/tutorial/android-arduino-udoo-simple-hello-world-tutorial/
    The app shows a null pointer exception during runtime, points to the lines below
    if (buttonLED.isChecked()) {
    mAdkManager.writeSerial("1");
    } else {
    mAdkManager.writeSerial("0");
    After uploading to UDOO, the app stops working when the toggle buton is clicked, and also the Arduino shows the message "No installed apps work with this USB accessory" when the OTG connection is disabled while trying to reconnect with arduino's SAM 3X8E.
    How can I solve this issue?
    Mariam
  2. xiamingliang
    xiamingliang New Member
    Mar 25, 2016
    check the log/java backtrace
    it tells the problem
    if it points to if (buttonLED.isChecked()) {
    it must be buttonLED is null
  3. Mariam
    Mariam New Member
    Mar 20, 2016
    10
    the error points to the lines in bold , mAdkManager.writeSerial("1");
    Check my new post, in ADKToolkit latest version uses write function instead of writeSerial and the following is the error log
    FATAL EXCEPTION: main
    Process: com.cocosystemsolutions.www.myled, PID: 1633
    java.lang.NullPointerException
    at me.palazzetti.adktoolkit.AdkManager.write(AdkManager.java:125)
    at me.palazzetti.adktoolkit.AdkManager.write(AdkManager.java:119)
    at com.cocosystemsolutions.www.myled.MainActivity$1.onClick(MainActivity.java:53)
    at android.view.View.performClick(View.java:4438)
    at android.view.View$PerformClick.run(View.java:18422)
    at android.os.Handler.handleCallback(Handler.java:733)
    at android.os.Handler.dispatchMessage(Handler.java:95)
    at android.os.Looper.loop(Looper.java:136)
    at android.app.ActivityThread.main(ActivityThread.java:5001)
    at java.lang.reflect.Method.invokeNative(Native Method)
    at java.lang.reflect.Method.invoke(Method.java:515)
    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:785)
    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:601)
    at dalvik.system.NativeStart.main(Native Method)
  4. johnsonjeven
    johnsonjeven New Member
    Oct 5, 2016
    The NullReferenceException is designed as a valid runtime condition that can be thrown and caught in normal program flow. It indicates that you are trying to access member fields, or function types, on an object reference that points to null. That means the reference to an Object which is not initialized.
    Johnson
