Android boot error
Discussion in 'Android' started by Arca, Dec 17, 2015.
  1. Arca
    Arca New Member
    Dec 9, 2015
    hello, i have Udoo Quad + 15.6" LCD.
    My goal is build android KitKat(4.4.2) and run on udoo board.
    so, i follow below guide
    "Compile Android From Sources"
    but, android boot failed.
    U-Boot 2009.08 (12ì›” 14 2015 - 14:26:52)
    CPU: Freescale i.MX6 family TO1.2 at 792 MHz
    Thermal sensor with ratio = 179
    Temperature:   28 C, calibration data 0x56e4e169
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock     : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock    : 80000000Hz
    cspi clock    : 60000000Hz
    ahb clock     : 132000000Hz
    axi clock   : 264000000Hz
    emi_slow clock: 132000000Hz
    ddr clock     : 528000000Hz
    usdhc1 clock  : 198000000Hz
    usdhc2 clock  : 198000000Hz
    usdhc3 clock  : 198000000Hz
    usdhc4 clock  : 198000000Hz
    nfc clock     : 24000000Hz
    Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR]
    Boot Device: NOR
    I2C:   ready
    DRAM:   1 GB
    MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:c0:08:88:b2:84
    FEC0 [PRIME]
    booti: bad boot image magic
    fastboot is in init......flash target is MMC:2
    USB Mini b cable Connected!
    fastboot initialized
    USB_SUSPEND
    The above situation.
    so, I changed bootargs
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,1366x768M@60,if=RGB24,bpp=32 video=mxcfb1: off video=mxcfb2: off fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
    but the situation is the same.
    Is there anyone who successfully download the Android 4.4.2 in udoo quad?
  2. Andrea Rovai
  3. Arca
    Arca New Member
    Dec 9, 2015
  4. iddqd
    iddqd Member
    Mar 24, 2014
    56
    11
    I recently compile it with that manual without errors on ubuntu.
  5. Arca
    Arca New Member
    Dec 9, 2015
    Did you try to download an image to the board?
    How did work well?
  6. iddqd
    iddqd Member
    Mar 24, 2014
    56
    11
    I compile it in virtual machine and I my internal sd-card reader don't work in vm. So I created one more virtual hdd and make image with make_sd.sh script on that virtual hdd.
    After that I make dd if=\dev\sdb of=zz.img download resulting image on windows machine and use win32diskimager to make sd-card.
    Then I successfully boot resulting image on udoo
  7. Arca
    Arca New Member
    Dec 9, 2015
    Thank you.
    When I proceed in the way that you said. so it is successfully operation to boot.
    But I do not know that it is not to run the script make_sd.
  8. Andrea Rovai
    Dear Arca,
    what do you mean by "But I do not know that it is not to run the script make_sd."?
  9. sayocandra
    sayocandra New Member
    Jul 1, 2016
    Dear @Arca,
    Could you tell me what kind of vm (os,configuration,etc) you use to compile android source code?
    Thank you.
