hi, i am building android for udoo neo, i have build successfully and working fine. Now i have select driver for tsc2007 touch under device driver ---> input device support ---> touch screens ----> <M> TSC2007 based touchscreens then i save and exit when i give make command on terminal i can't generate tsc2007.ko and i got following error including ./system/vold/Android.mk ... including ./tools/external/fat32lib/Android.mk ... No private recovery resources for TARGET_DEVICE udooneo_6sx build/core/main.mk:1038: warning: overriding commands for target `clean' external/tools/iw/Makefile:126: warning: ignoring old commands for target `clean' mkdir -p out/target/product/udooneo_6sx/obj/KERNEL_OBJ rm -f out/target/product/udooneo_6sx/kernel make -C kernel_imx udoo_neo_android_defconfig ARCH=arm CROSS_COMPILE=`pwd`/prebuilts/gcc/linux-x86/arm/arm-eabi-5.3/bin/arm-eabi- LOADADDR=0x80008000 O=`pwd`/out/target/product/udooneo_6sx/obj/KERNEL_OBJ GEN /home/malar/myandroid/out/target/product/udooneo_6sx/obj/KERNEL_OBJ/Makefile # # configuration written to .config # make -C kernel_imx -j4 uImage ARCH=arm CROSS_COMPILE=`pwd`/prebuilts/gcc/linux-x86/arm/arm-eabi-5.3/bin/arm-eabi- LOADADDR=0x80008000 O=`pwd`/out/target/product/udooneo_6sx/obj/KERNEL_OBJ if [ ! -e include/config/auto.conf ]; then make -f /home/malar/myandroid/kernel_imx/Makefile silentoldconfig ; fi CHK include/config/kernel.release GEN /home/malar/myandroid/out/target/product/udooneo_6sx/obj/KERNEL_OBJ/Makefile CHK include/generated/uapi/linux/version.h if [ ! -e include/config/auto.conf ]; then make -f /home/malar/myandroid/kernel_imx/Makefile silentoldconfig ; fi Using /home/malar/myandroid/kernel_imx as source for kernel /home/malar/myandroid/kernel_imx is not clean, please run 'make mrproper' in the '/home/malar/myandroid/kernel_imx' directory. CHK include/generated/utsrelease.h make[2]: *** [prepare3] Error 1 make[1]: *** [sub-make] Error 2 make: *** [out/target/product/udooneo_6sx/kernel] Error 2 #### make failed to build some targets (02:41 (mm:ss)) #### i am following procedures from this Link https://www.udoo.org/docs-neo/Advanced_Topics/Compile_Android_From_Source.html if i made any mistake please let me know... i am using ubuntu 14.04 64 bit system. thank you,
I'm trying to build an Android kernel for the arm architecture, but it fails all the time and it gives me this error: Using /home/build/tommolini_android/omap-android-kernel as source for kernel /home/build/tommolini_android/omap-android-kernel is not clean, please run 'make mrproper' in the '/home/build/tommolini_android/omap-android-kernel' directory. make[1]: *** [prepare3] Error 1 make[1]: *** Waiting for unfinished jobs.... HOSTLD scripts/mod/modpost make[1]: *** wait: No child processes. Stop. make: *** [sub-make] Error 2 If I run make mrproper inside that directory and do again make ARCH=arm -j8 it says that it doesn't find .config file: *** *** Configuration file ".config" not found! *** *** Please run some configurator (e.g. "make oldconfig" or *** "make menuconfig" or "make xconfig"). *** make[3]: *** [silentoldconfig] Error 1 make[2]: *** [silentoldconfig] Error 2 make[1]: *** No rule to make target `include/config/auto.conf', needed by `include/config/kernel.release'. Stop. make: *** [sub-make] Error 2. snaptube vidmate word to pdf
