Android with LVDS 7'/ HDMI
Discussion in 'UDOO NEO' started by vudoo, Jun 14, 2017.
Tags:
  1. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    I am having trouble on making android to show something on screen. I installed the image and tested that works using the debugger.
    I am not trying to use LVDS and HDMI simultaneously. To set the output I used the commands provided here.
    The problem is that If I do so I am getting stuck to "Starting kernel...." message.
    Is there a difference between quad/dual and neo that cause this problem?
    2,306
    578
  3. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    How did I miss that? The weird thing is that the default option doesn't work for me.
  4. waltervl
    2,306
    578
    You mean you have no output when you connect your Neo to an HDMI monitor and you start with a new burned Android image?
  5. vudoo
    vudoo New Member
    Jun 14, 2017
    17
    That's right. I tried another monitor today and it worked. Looks like the previous one has a faulty HDMI connector.
