apt-get not working on UDOObunutu
Discussion in 'Linux Ubuntu' started by batchku, Jul 18, 2014.
  1. batchku
    batchku New Member
    Jul 11, 2013
    17
    i'm trying to install the dependencies for compiling OpenFrameworks with the latest udoobuntu release
    i'm finding that apt-get is not finding any of the packages
    i've tried updating and upgrading apt-get, synaptic is installed, and my list of repositories in "/etc/apt/sources.list" has:
    deb http://ports.ubuntu.com/ precise main restricted universe multiverse
    nonetheless, trying to install things like "openssl" or "libudev" or "gstreamer-app-0.10" with apt-get is giving me:
    "E: Unable to locate package ***"
    does anyone see what i'm doing wrong?
    ali
  2. peter247
    peter247 Member
    Mar 10, 2014
    263
    Have you checked you have a working internel connection + a dns nameserver and default gateway ?.
    log into a terminal and try "ping google.co.uk" and see if it resolves to a ip address
  3. batchku
    batchku New Member
    Jul 11, 2013
    17
    i definitely have a working internet connection.
    ping works and browser works.
    anything else?
  4. peter247
    peter247 Member
    Mar 10, 2014
    263
    Have you tried installing via synaptic and see if it will install anything new at all.
    Check the /var/logs and see if you are get errors on the sd card or try making a new image.
    is it a permissions problem ? , No can`t be that because you are installing as a root user with sudo.
  5. pashakun
    pashakun New Member
    Nov 9, 2014
    having the same problem
    batchku, were you able to fix?
  6. Andrea Rovai
