Hello, I am wondering if my arduino 101 is dead. I power my udoo x86 and detect the arduino 101 with the arduino IDE. I can send code and use the serial connection. However when I try to light up a LED with the +5V and 3,3V nothing happens.( I already verified and I have 5V and 3,3V between the pins.) Same if I use an output as high to light up the LED. Seems like I can't draw current out of the arduino 101. Best Regards,
If you upload the blink example will the built in LED (pin 13) blink? How did you connect your LED? What resistor did you use?
