Hi , I`m running the Debian hard float image and installed arduino ide using this :- http://www.elinux.org/UDOO_install_the_Arduino_IDE I tested it out using the blink sketch with the following error ( Blinking led , so did work ). Code: /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c:(.text._sbrk_r+0xc): warning: undefined reference to `_sbrk' Which is the same error which I got on the ubuntu image , so thought this was normal and working. Now after getting the quad core part working with all my software installed and rootfs now copied to the sata I`ve started to look at the arduino part. Now tried to compile one of the i2c / wire sketches which came up with the following errors Code: /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c:(.text._sbrk_r+0xc): warning: undefined reference to `_sbrk' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-abort.o): In function `abort': abort.c:(.text.abort+0xa): warning: undefined reference to `_exit' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-signalr.o): In function `_kill_r': signalr.c:(.text._kill_r+0xe): warning: undefined reference to `_kill' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-signalr.o): In function `_getpid_r': signalr.c:(.text._getpid_r+0x2): warning: undefined reference to `_getpid' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-writer.o): In function `_write_r': writer.c:(.text._write_r+0x10): warning: undefined reference to `_write' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-closer.o): In function `_close_r': closer.c:(.text._close_r+0xc): warning: undefined reference to `_close' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-fstatr.o): In function `_fstat_r': fstatr.c:(.text._fstat_r+0xe): warning: undefined reference to `_fstat' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-isattyr.o): In function `_isatty_r': isattyr.c:(.text._isatty_r+0xc): warning: undefined reference to `_isatty' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-lseekr.o): In function `_lseek_r': lseekr.c:(.text._lseek_r+0x10): warning: undefined reference to `_lseek' /root/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-readr.o): In function `_read_r': readr.c:(.text._read_r+0x10): warning: undefined reference to `_read' Sketch uses 29,036 bytes (5%) of program storage space. Maximum is 524,288 bytes. I`ve tried the same using the pc method and compile which only a little error : cygwin warning: MS-DOS style path detected: .. no problem !- I know that it need a "at least this version" , of java how do I tell which version is installed ? , I may be a little confused on is how it compiles !! On the PC the compiler is within the arduino base , because window is always i386 based. so it compile i386 to amega / arm I guess on the due . But with Linux it can be i386 or arm etc , so what and where is the compiler the standard GCC ? to and from arm. and any clues to what is my problem ?
I`ve worked out the answer to my own question on the compiler . When you download the code Linux they assume you are still running on a i386 system , which is true 99.999999999999% of the time. I`ve read a post saying the errors are due to commented out lines in /root/arduino-1.5.4/hardware/arduino/sam/cores/arduino/iar_calls_sam3.c Code: /* Copyright (c) 2011 Arduino. All right reserved. This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details. You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */ /** * \file * * Implementation of low level library. * */ #if defined __ICCARM__ /* IAR Ewarm 5.41+ */ #include "board.h" #include <stdio.h> #include <stdint.h> #include <stddef.h> #include <yfuns.h> #include <uart.h> extern __weak size_t __write( int handle, const unsigned char *buf, size_t bufSize ) { size_t nChars = 0 ; /* Check for the command to flush all handles */ if ( handle == -1 ) { return 0 ; } /* Check for stdout and stderr (only necessary if FILE descriptors are enabled.) */ if ( handle != 1 && handle != 2 ) { /* remove warnings */ return 0xfffffff ; } for ( /* Empty */ ; bufSize > 0 ; --bufSize ) { while ( !uart_is_tx_ready(CONSOLE_UART) ) ; uart_write( CONSOLE_UART, *buf ) ; ++buf ; ++nChars ; } return nChars ; } extern __weak size_t __read( int handle, unsigned char *buf, size_t bufSize ) { size_t nChars = 0 ; /* Check for stdin (only necessary if FILE descriptors are enabled) */ if ( handle != 0 ) { /* remove warnings */ return 0xfffffff ; } for ( /*Empty*/; bufSize > 0 ; --bufSize ) { uint8_t c; while (uart_read( CONSOLE_UART, &c )) ; if ( c == 0 ) { break ; } *buf++ = c ; ++nChars ; } return nChars ; } /** * \brief Outputs a character on the UART. * * \param c Character to output. * * \return The character that was output. */ extern __weak signed int putchar( signed int c ) { while ( !uart_is_tx_ready(CONSOLE_UART) ) ; uart_write( CONSOLE_UART, c ) ; return c ; } #endif // defined __ICCARM__ It looks like that is not my problem here !!!.
Have you solve this issue? I'm having it too. Could you link the post you refer to or explain it a little more about the commented part? When it compiles I have: Code: /opt/arduino-1.5.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/thumb/libc.a(lib_a-sbrkr.o) In function `_sbrk_r':sbrkr.c:(.text._sbrk_r+0xc): warning: undefined reference to `_sbrk'
Hi Guys, It's just an idea, beacause I haven't got this trouble... But have you try to use the last arduino version 1.5.6-r2 and compile with it? See you soon!
I downloaded the Linux. version, but found it was pre compiled for i386. Is there a source version, where I can compile it myself?
I think you can find it here ^^ : http://arduino.cc/en/Main/Software#toc3 For x86 and x64 Linux architecture... An other question? Bye!
Yep , I`ve download the source files and it is still only designed for I386 . I will have to work out to add ARM to the arc list . ( build.xml )
