I'm running the current Arduino IDE (v1.5.4) on a UDOO Quad. Most programs work fine (thanks guys), but I've noticed one strange issue: the Arduino Serial.print(x) and Serial.println(x) functions cause program execution to freeze if x is a floating point number. Integers seem to be OK. Has anyone faced this issue before? The only reference to a similar problem that I found can be seen here: http://forum.arduino.cc/index.php?topic=174874.0.
Sounds like it might be a armel/armhf issue possibly. Are you using the stock Linaro Ubunto 11.10 version 1.2 from this site, and then ran the update?
Hi all, I can not even get any serial print functions to display anything. I am using: Linux udoo 3.0.35 #1 SMP PREEMPT Thu Nov 28 13:14:24 CET 2013 armv7l armv7l armv7l GNU/Linux What in the world to do. This problem makes the Arduino side kind of worthless. Any assistance would be appreciated. V/r dantavious
I don't think that is enough information to go on. Feel free to post a code snippet and perhaps we can spot what the issue is.
Hi, Thanks for the reply. I am actually using the code from the udoo website. http://www.udoo.org/ProjectsAndTutorial ... lioID=1394 I am not able to get any serial output. What else could the problem be. #include <dht11.h> dht11 DHT11; #define DHT11PIN 13 int led_hum = 12; int led_temp = 11; void setup() { // put your setup code here, to run once: delay(5000); Serial.begin(9600); Serial.println("UDOO & DHT11 - TEST PROGRAM By Alessandro Paghi"); Serial.println("Humidity (%)\tTemperature (C)\tLed_Hum\t\tLed_Temp"); pinMode(led_hum,OUTPUT); pinMode(led_temp,OUTPUT); } void loop() { // put your main code here, to run repeatedly: DHT11.read(DHT11PIN); Serial.print(DHT11.humidity); Serial.print("\t\t"); Serial.print(DHT11.temperature); Serial.print("\t\t"); if(DHT11.humidity>45) { digitalWrite(led_hum,HIGH); Serial.print("ON\t\t"); } else { digitalWrite(led_hum,LOW); Serial.print("OFF\t\t"); } if(DHT11.temperature>23) { digitalWrite(led_temp,HIGH); Serial.println("ON"); } else { digitalWrite(led_temp,LOW); Serial.println("OFF"); } delay(2000); }
