armel or armhf?
Discussion in 'General Discussion' started by jerrino77, Dec 3, 2013.
  1. jerrino77
    jerrino77 UDOOer
    Nov 25, 2013
    31
    Ok, maybe I understand the difference between armel and armhf, in theory.. but what's the difference in "everyday use"? I mean, for a multimedia home server, I will get more or less using armel instead of my actual Debian armhf image? Thanks
  2. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    The general rule will be that armhf is at least the same performance as armel, and often faster. It depends on how much use is made of floating point in the app in question as armhf speeds up floating point operations.
  3. jerrino77
    jerrino77 UDOOer
    Nov 25, 2013
    31
    Well, Don't know if I need floating point or not. My needs are to have a multimedia server, with transmission, amule and oscam running 24/7
  4. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    It all depends on exactly how those programs are encoded. Without feedback from the authors I do not know how you can tell if they use floating point. If they internally use floating point then you will get a performance gain from the amrhf version.
  5. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    I doubt you'd be able to detect a difference in your stated Use Case.
    I'd recommend you go with armel as that is the more stable at the moment.
  6. jerrino77
    jerrino77 UDOOer
    Nov 25, 2013
    31
    ok, thank you, i will try
  7. ndzinn
    ndzinn New Member
    Nov 30, 2013
    31
    It depends on your use case, of course. I have some experience with the test code in the link below run on squeeze (Debian 6, armel) and wheezy (Debian 7, armhf) on a commercial SBC (not RPi, or BBB or Udoo).
    viewtopic.php?f=2&t=470#p3807
    Wheezy runs this code 5 times faster than squeeze. This is heavy math hitting the FPU; armhf cuts it (hard floats), armel doesn't (soft floats). Depends on your use case. My use case demands armhf!
    Noel
  8. Flamenawer
    Flamenawer Member
    Nov 2, 2013
    66
    I am noob on Linux, how to swap between armel and armhf on Udoo Linaro or ROS?
    Excuse my english
  9. Lifeboat_Jim
    Sep 16, 2013
    399
    In effect you swap by switching SD card, with the different versions on each (or if you have one SD, you reimage)
  10. Flamenawer
    Flamenawer Member
    Nov 2, 2013
    66
    Thank you for all your posts, always helping. I hope can do it some day.
  11. profoundWHALE
    profoundWHALE New Member
    Nov 18, 2013
    I tried out the debian wheezy armhf build and the ubuntu 12.04, and the armhf was definitely faster.
  12. allwet
    allwet New Member
    Oct 30, 2013
    29
    Does the new v2.1 ubuntu 12.04 build for the UDOO quad support armhf? I'm interested for future floating point applications development.
  13. delba
    1,064
    No sorry, the new v2.1 ubuntu 12.04 is armel. But we're planning to release the armHF version of Ubuntu 12.04 (beta) in a couple of weeks.
