I've been trying for the last month to stream realtime video and audio from Udoo to a server running crtmpserver (or wowza streaming server). I struggled with Gstreamer for a while, and was unsuccessful. I have had success in the past with ffmpeg on Raspberry Pi, but that board didn't quite have the power to stream video and audio. I've managed to successfully put together a ffmpeg pipeline that works, and I thought I would post it here for anyone trying to do the same. If anyone knows any way that this could be optimized further, please let me know, as I'm little more than a newbie. I'm using the latest UDOObuntu image, which has the camera module loop through to /dev/video7 I'm using the built-in microphone jack for audio. I compiled and installed ffmpeg and dependencies using this guide: http://www.raspberrypi.org/forums/viewt ... 43&t=53936 The following are my own steps based on it ( again, there may be more optimal ways to do this): Install dependencies Code: sudo apt-get -y install autoconf automake build-essential libass-dev libfreetype6-dev libgpac-dev libsdl1.2-dev libtheora-dev libtool libva-dev libvdpau-dev libvorbis-dev libx11-dev libxext-dev libxfixes-dev pkg-config texi2html zlib1g-dev libasound2-dev Install Yasm Code: cd /usr/src wget http://www.tortall.net/projects/yasm/releases/yasm-1.2.0.tar.gz tar xzvf yasm-1.2.0.tar.gz cd yasm-1.2.0 ./configure make make install Install h.264 video encoder Code: cd /usr/src git clone git://git.videolan.org/x264 cd x264 ./configure --disable-asm --enable-shared make make install Install mp3 audio encoder Code: cd /usr/src wget http://downloads.sourceforge.net/project/lame/lame/3.99/lame-3.99.tar.gz tar xzvf lame-3.99.tar.gz cd lame-3.99 ./configure make make install Install aac encoder Code: cd /usr/src curl -#LO http://downloads.sourceforge.net/project/faac/faac-src/faac-1.28/faac-1.28.tar.gz tar xzvf faac-1.28.tar.gz cd faac-1.28 ./configure make make install If you get errors, edit common/mpeg4ip.h comment out line 126 Install libfdk aac Code: wget -O fdk-aac.zip https://github.com/mstorsjo/fdk-aac/zipball/master unzip fdk-aac.zip cd mstorsjo-fdk-aac* autoreconf -fiv ./configure make make install Install libopus audio encoder Code: cd /usr/src wget http://downloads.xiph.org/releases/opus/opus-1.1.tar.gz tar xzvf opus-1.1.tar.gz cd opus-1.1 ./configure make make install Install ffmpeg ( 'make' will take a couple of hours) Code: cd /usr/src/ git clone git://source.ffmpeg.org/ffmpeg.git cd ffmpeg ./configure --enable-shared --enable-gpl --prefix=/usr --enable-nonfree --enable-libmp3lame --enable-libfaac --enable-libx264 --enable-version3 --disable-mmx --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libopus --enable-libtheora --enable-libvorbis make make install Set load library location Code: LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib ffmpeg ldconfig That should do it as far as installing ffmpeg goes. You can double check by getting the version: Code: ffmpeg -version and checking the codecs installed: Code: ffmpeg -codecs If everything checks out, you should be able to run a ffmpeg pipeline. Here is the one that I've gotten to work to stream audio and video: Code: ffmpeg -f video4linux2 -video_size 640x480 -framerate 30 -input_format yuyv422 -i /dev/video7 -f alsa -i hw:0,0 -map 0:0 -map 1:0 -vcodec libx264 -preset ultrafast -b:v 150k -bufsize 150k -acodec aac -vbr 3 -strict -2 -f flv -metadata streamName=myStream tcp://192.168.1.20:6666
Was this finally included in the recent version? I am trying to replicate it (only video) but so far the stream runs, I can connect to it but I can't see anything (using vlc for Android as a client). Enric
