Barometric Temperature Altimeter Sensor in Neo
Discussion in 'UDOO NEO' started by Aimar Dynamik, Jul 12, 2016.
  1. Aimar Dynamik
    Aimar Dynamik New Member
    May 3, 2016
    28
    Hi
    Is there any way to connect this sensor kit into the arduino processor in the neo?
    I could not find any tutorial even if it is a official product in the udoo shop.
    Thanks in advance
  2. ektor5
    Jul 1, 2013
    97
    48
    Hi there,
    from the docs: http://www.udoo.org/docs-neo/Cookbook_Linux/Device_Tree_Editor.html
    I2C-2: SNAP-IN Bricks connector
    By default the snap-in connector is assigned to the A9 and it’s possible to control it by Linux driver. The I2C signal are also available on SDA - SCL pins and on pins 36/37.
    If you need to use this on the M4 Arduino core, you need to remove it from the A9 core, right-clicking on the corresponding pins and removing it.
    After a reboot it will be possible to connect an external I2C device to the SDA SCL pins and control it from the Arduino M4 core.
    The Arduino Libraries are already in the UDOO Board Package.
    BR,
    Ek5
    Andrea Rovai likes this.
  3. bryan20miles
    bryan20miles New Member
    Mar 10, 2016
    11
    Where can I find a Arduino code example?
    Thank you.
  4. waltervl
    In the Arduino IDE in the file - examples section if you have installed the Neo board package or on the preinstalled IDE on the Neo itself.
