Battery for UDOO x86
Discussion in 'UDOO X86' started by Piero78, Jun 7, 2016.
  1. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    I know. If you read the original post I jokingly replied to it said, "To [sic] bad that powerbanks can't be used when charging."
  2. toriless
    toriless New Member
    Jun 25, 2016
    17
    While, their E7 26800 mAh works fine doing both, I double checked it before answering, as does the E3 so I think their entire new Astro line does.
  3. toriless
    toriless New Member
    Jun 25, 2016
    17
    My darn Sony Bluetooth headphones can not be used while charging. It is the only rechargeable item I have like that.
  4. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    The Anker website FAQ indicates the E7 cannot be charged when charging/powering other devices: https://www.anker.com/products/A1210012
    Also, the E7's output is only 60-70% efficient, so the original problem noted in this thread (is the battery pack output regulated?) remains in doubt.
    UPDATE: I just noticed the Anker Astro battery packs are 5v output, and the UDOO X86 requires 12v regulated +/- .nn volts.
  5. toriless
    toriless New Member
    Jun 25, 2016
    17
    While the their FAQ is fucking WRONG!!!! State what tou want I have the evidence and not some wiki like internet lie.
  6. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
  7. waltervl
    2,312
    A little bit offtopic but why connect an extra arduino when the udoo has an arduino build in? Do you have to use 2 arduino's? If you need extra io you could also use the x86 io.
  8. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
    My robot will have 20 servos, can the Udoo x86 control this numbers of servos?
  9. FirstGenGeek
    FirstGenGeek Member
    May 25, 2016
    66
    26
    Just like any standard Arduino board the UDOO X86 shouldn't power any servos. If you look back to the start of this thread you will find the following:
    "With respect to the servos you will likely want to have a separate regulated battery power supply. This guide will help: https://cdn-learn.adafruit.com/downloads/pdf/16-channel-pwm-servo-driver.pdf "
  10. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
    I will use 2 boards (UDOO X86 and Arduino MEGA with expansion board) with 2 batteries. Now, can my solution posted before power the UDOO X86?
  11. waltervl
    2,312
    For 20 servo's you could also use something like this http://www.lamja.com/?p=504
    In this sulution the servos are separately powered. An I2C expansion board as FirstGenGeek proposed is also a very good alternative. And even better than the other because that relies on Arduino Uno timers wich I don't know if they are compatible with the Curie ones.
    So to control 20 servo's you only need 1 Arduino. To power them you need external power. The battery size is also depends how heavy you use the servo's.
    FirstGenGeek likes this.
  12. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
    UDOO X86 is a board design for makers, the staff has to explain how to connect it to a external battery. I wait an OFFICIAL solution.
  13. waltervl
    2,312
    I think they are not ready yet. The Udoo Quad, Dual and Neo need a power supply between 6 and 15 Volt so very tolerant. I expect the Udoo X86 having the same specs so no need for a regulated power source as long as it is stable. A battery is stable per design so for the time being just plan to use any 12 V battery and be sure that during loading it is not peaked over 15V ( if connected to the board).
  14. waltervl
    2,312
    Servo's normally run on 5-6V so you need another battery pack for the servo's. Or put 2 6V packs in serial for the Udoo and use 1 of the 2 to power the servo's.
  15. Bullaus
    Bullaus New Member
    Aug 9, 2016
    11
  16. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
  17. waltervl
    2,312
    Probably OK to power the board (waiting for power input specs). Not OK to power the servo's.
  18. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
    I will use 2 batteries.
  19. waltervl
    2,312
  20. Piero78
    Piero78 New Member
    Jun 6, 2016
    16
    News about an OFFICIAL battery for the board?
