Benchmarking udoo v cubitruck v raspberry pi
Discussion in 'General Discussion' started by peter247, Mar 18, 2014.
  1. peter247
    peter247 Member
    Mar 10, 2014
    263
    Just done a little test on all my platforms, by running this python script which generates prime numbers .
    #!/usr/bin/python
    import sys
    import math
    def is_prime(num):
    	for j in range(2,int(math.sqrt(num)+1)):
    		if (num % j) == 0:
    			return False
    	return True
    def main(argv):
    	if (len(sys.argv) != 3):
    		sys.exit('Usage: prime_numbers3.py <lowest_bound> <upper_bound>')
    	low = int(sys.argv[1])
    	high = int(sys.argv[2])
    	if (low == 2):
    		print 2,
    	if (low % 2 == 0):
    		low += 1
    	for i in range(low,high,2):
    		if is_prime(i):
    			print i,
    if __name__ == "__main__":
    	main(sys.argv[1:])
    run with :- time ./prime.py 0 1000000 > /dev/null
    All running Debian 7 and very little load , No gui desktop running. ( just headless )
    all standard images downloaded from the makers web sites , no extra clocking from the default image.
    eg the udoo was the udoo_quad_debian_wheezy_armhf_v1.0beta image .
    Cubitruck and udoo running on sata and the raspberry on a class 10 sd card.
    Cubitruck 1 = minutes 29 seconds to 1 minutes 32 seconds ... run 3 times
    Raspberry Pi = 3 minutes 45 seconds to 4 minutes 9 seconds .. run 3 times
    Udoo =  49.566 seconds to 49.701 seconds .. run 3 times
    And that using a single core on all platforms
  2. delba
    1,064
    Simple but very effective benchmark, thanks peter247 ;)
