BIOS Problem
Discussion in 'UDOO X86' started by Intermez, Sep 4, 2017.
  1. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Can't seem to get new BIOS to load. Have an Advanced with Bios 1.1 Running Win 7 and followed the pdf procedures to load 1.3. All seems OK with proper responses and finally says it requires a reboot to finish. Reboot and still only see rev 1.1 on the SCU menu item. I don't know Linux, although have Ubuntu as a boot option....plan on learning Linux but figured now is not the time for it while messing with BIOS.
    Any help would be appreciated as rev 1.3 hopefully will help my fan problem (only runs at startup) and the board periodically shuts down by itself I assume due to overheating.
    Thanks in advance,
    Kevin
  2. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
  3. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Yes, went back a tried two more times. I'm sure I running as admin and the file is writing to memory. It shows I'm updating from 1.01 to 1.03. writes the new file, and asks for a reboot. Still shows 1.01 as the boot version in SCU. Don't know what to try, any suggestions?
    Thanks, Kevin
  4. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Now seeing the following ERROR when I run bios_updater_x64:
    Error: INISI 14h read compare fail after write. Address:FF804000
    then it appears to write again and see the same error at a different address: FF804000
    Is this what is causing it not to install 1.03? What do I do now???? HELP??
  5. waltervl
    2,237
    561
    Do you use win 7 64b or 32b? You should use the appropriate bios_updater for that.
    If it still fails It perhaps is easier to make a bootable FreeDOS USB and update from that. For instructions how to update with DOS see the PDF in the update ZIP.
  6. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Guess I'm not sure what win 7 64b is. I'm running Win7 pro x64. Did I miss something?
  7. x1800MODMY360x
    x1800MODMY360x Member
    Mar 29, 2017
    55
    Type what command you are using here.
  8. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Command I'm using:
    bios_updater_x64 0B020000.103
  9. waltervl
    2,237
    561
    Are you sure you have started the dos box with option "run as administrator"? You not only have to be an administrator, you also have to start it with this option. See also
  10. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Thanks for the reply,
    Yes, definitely running as administrator. In fact I tried it two different ways. First used ctrl-shift-enter after typing cmd and it enters at user/username. Also tried going to Accessories, right click Command prompt, run as administrator. It enters at c:\windows/system32.
    I ran the updater both ways and the error still occurs. Also the fact that it is writing to memory during the update verifies that it is being run as administrator. When not running as administrator it does not write to memory at all.
    Is there something else I can check to find the problem? Suggestions ???????????
  11. waltervl
    2,237
    561
  12. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    I tried the FreeDos booting from a usb stick. Took a while to get it done. Same result.
  13. Maurice
    Oct 13, 2015
    394
    87
    Time to contact customer support.
  14. waltervl
    2,237
    561
    Yep
  15. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Looked on udoo.org but don't see customer support or entering a trouble ticket. How do I get to customer support?
  16. itimpi
    itimpi UDOOer
    Oct 31, 2013
    119
    33
    Go to the bottom of the main UDOO home page and there is a Customer Care link that takes you to a page where you can raise a support ticket
  17. Intermez
    Intermez New Member
    Jun 6, 2017
    28
    Thanks, appreciate it. Somehow I missed it...duh!
