BIOS upgrade timeline for fan fix ?
Discussion in 'UDOO BOLT' started by Erkki, Aug 28, 2019.
Tags:
  1. evaloverde
    Apr 29, 2019
    236
    59
    Ciao Micka,
    have you sent this to Ettore too? This is precious information for us to know.
    WisdomWolf likes this.
  2. Micka41
    Micka41 UDOOer
    Aug 26, 2019
    Yes, I sent him an email
  3. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    I found that the first few boots after the BIOS upgrade took MUCH longer than expected (so much so that I initially thought I may have had a bricked system). I reported this back as something that users should be made aware of. However the boot time has now returned to normal so in that sense all is good. I probably have also done a power off since the upgrade - not sure if that is relevant as well in getting boot times back to normal.
    BoltyBolt likes this.
  4. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    49
    26
    Same here. BIOS 1.05 RC13. After initial post-flash reboot, post is super slow, even entering BIOS and navigating BIOS menus took extraordinary long time. Could be due to fact that Embedded Controller as well as USB-C susbsystem is also updated. Only after a "Restore Defaults" & "Save Changes" from BIOS menu, followed by full power cycle things went back to "normal".
    @itimpi are you also on 1.05 RC13?
  5. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    Yes.
    I also have the ‘v’ variant of the fan (one with the green dot) so I wonder if this was why I saw no obvious reduction in fan noise from this version of the BIOS? Currently running with a Gelid Silent 6 fan which is either on or off, but since I cannot hear it when on unless I put my ear just a few inches from the Bolt this effectively solves the noise issue for me.
  6. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    49
    26
    I highly suspect so. If you check history.txt supplied with BIOS update files, there are several mentions of "bad" FANs. I strongly believe that H05BIV aka "green dot" fan variant is the very example of this "bad" FAN, that is physically incapable of being RPM controled when connected to Udoo Bolt Embedded Controller, which makes BIOS PWM control settings useless. Bolt's controller can only turn H05BIV on and off.
  7. Ratz Fatz
    Ratz Fatz UDOOer
    Nov 7, 2019
    Please could someone who received the new Beta BIOS do me a favor and post the output of
    dmesg | grep -i TPM
    under Linux?
    Currrently (BIOS version 1.05 RC8) the tpm doesn't work on my my board: the output of the above command is:
    [ 0.000000] efi: TPMFinalLog=0x9dcdf000 ACPI 2.0=0x9db9e000 ACPI=0x9db9e000 SMBIOS=0x9e3a2000 SMBIOS 3.0=0x9e3a1000 MEMATTR=0x9a160018 ESRT=0x9bbba818
    [ 0.005172] ACPI: TPM2 0x000000009DBB9B00 000034 (v04 ALASKA A M I 00000001 AMI 00000000)
    [ 0.454180] tpm_crb MSFT0101:00: can't request region for resource [mem 0x9d762000-0x9d765fff]
    [ 0.454218] tpm_crb: probe of MSFT0101:00 failed with error -16
    [ 0.494982] ima: No TPM chip found, activating TPM-bypass!
    Thanks in advance!
  8. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    49
    26
    root@bolt:~# dmidecode -q -H 0x0000
    BIOS Information
        Vendor: American Megatrends Inc.
        Version: 1.05 R.C. 13
        Release Date: 10/23/2019
        Address: 0xF0000
        Runtime Size: 64 kB
        ROM Size: 8192 kB
        Characteristics:
            PCI is supported
            BIOS is upgradeable
            BIOS shadowing is allowed
            Boot from CD is supported
            Selectable boot is supported
            BIOS ROM is socketed
            EDD is supported
            5.25"/1.2 MB floppy services are supported (int 13h)
            3.5"/720 kB floppy services are supported (int 13h)
            3.5"/2.88 MB floppy services are supported (int 13h)
            Print screen service is supported (int 5h)
            Serial services are supported (int 14h)
            Printer services are supported (int 17h)
            ACPI is supported
            USB legacy is supported
            BIOS boot specification is supported
            Targeted content distribution is supported
            UEFI is supported
        BIOS Revision: 5.13
        Firmware Revision: 0.20
    root@bolt:~# dmidecode -q -H 0x0008
    TPM Device
        Vendor ID:
        Specification Version: 2.0    Firmware Revision: 3.34
        Description: AMD    Characteristics:
            Family configurable via platform software support
        OEM-specific Information: 0x00000000
    root@bolt:~# uname -a
    Linux bolt 5.3.0-19-generic #20-Ubuntu SMP Fri Oct 18 09:04:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
    root@bolt:~# dmesg | grep -i TPM
    [    0.000000] efi:  TPMFinalLog=0x9dcd9000  ACPI 2.0=0x9db98000  ACPI=0x9db98000  SMBIOS=0x9e39e000  SMBIOS 3.0=0x9e39d000  MEMATTR=0x9a7b9118  ESRT=0x9a627c98
    [    0.005494] ACPI: TPM2 0x000000009DBB3DE0 000034 (v04 ALASKA A M I    00000001 AMI  00000000)
    [    0.565485] tpm_crb MSFT0101:00: can't request region for resource [mem 0x9db0c000-0x9db0ffff]
    [    0.566143] tpm_crb: probe of MSFT0101:00 failed with error -16
    [    0.700596] ima: No TPM chip found, activating TPM-bypass!
  9. Zgembo
    Zgembo UDOOer
    Sep 21, 2019
    49
    26
    @Ratz Fatz As you can see, same here. I'd blame this totally on BIOS, as when I tried messing up with some TPM settings in BIOS, TPM disappeared altogether despite BIOS being set to "Enabled" (BIOS all other TPM options disappeared as well, only full "Load BIOS Defaults" made them come back)!
  10. Ratz Fatz
    Ratz Fatz UDOOer
    Nov 7, 2019
    Sad to hear that. So the TPM is completely unusable under linux, even with the latest Beta BIOS. I was planning to play around with secure boot and disk encryption with keys stored in the tpm (bitlocker-like).
    Shouldn't we open a separate thread for the TPM topic?
  11. Ratz Fatz
    Ratz Fatz UDOOer
    Nov 7, 2019
    Ok, I posted a new thread...
    Zgembo likes this.
  12. codepope
    codepope UDOOer
    Nov 15, 2019
    What did you use as an adapter or did you put a custom cable together?
  13. evaloverde
    Apr 29, 2019
    236
    59
    Zgembo likes this.
  14. evaloverde
    Apr 29, 2019
    236
    59
    Ciao guys, please email this info to Ettore, he needs to know.
    Zgembo likes this.
  15. Andy Carlson
    Andy Carlson New Member
    Apr 22, 2019
    The 1.06 Bios does not seem to help the fan noise. It almost wouldn't be as bad if it was on all the time, but the cycling on and off makes it mopre noticable.
  16. WisdomWolf
    WisdomWolf UDOOer
    Aug 21, 2019
    12
    Can you elaborate on how you went about mounting and connecting this fan. I purchased one because I was committed to making this thing quieter and I have one of the green dot fans. The springs on the screws that came with the stock fan don't exactly fit the gelid though and the connection on the fan is is different (I think the stock fan connection is micro JST?). I could probably figure out some ghetto solution, but I'm interested to hear how you did it in the hope that you have a more elegant solution.
  17. Julian
    Julian UDOOer
    Nov 28, 2019
    The 1.06R4 update killed my V8. The HDMI output became an epilepsy-inducing flashing mess, and it freezes on the UDOO BOLT logo (+20 mins tested). See the joined screenshot.
    Specs :
    UDOO BOLT V8
    16 (8x2) GB 2400MHz DDR4
    No SATA/PCI-E device installed
    Bios updated on Ubuntu 18.04 using the tool in the archive, no errors during the flashing process. I tried resetting the BIOS settings, to no avail. The fan seems to work fine (though no improvement in noise)
    [​IMG]
  18. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    You can buy short 6” leads with the Bolt board connector already fitted (I got 5 for £2.50 on eBay) and I soldered one of these in place of the connector on the Gelid.
  19. WisdomWolf
    WisdomWolf UDOOer
    Aug 21, 2019
    12
    Makes sense, what about the screws/springs needed to mount the fan on the heatsink?
  20. itimpi
    itimpi UDOOer
    Oct 31, 2013
    136
    39
    . I just used the ones provided (although I turned the springs upside down).
